http://www.hm-moreart.de |
#2 |
why FAST ?? just a name ?
#3 |
known as an fullrange with sub helper system.
last minute 2 new pic coming.
#4 |
Hartono,
F.A.S.T. = Fullrange And Subwoofer Technology. Pit |
#5 |
is there an actual picture of the speaker?
gychang |
#6 |
Thanks Pit,
gychang, an idea, built in the next month, but with BMS H 4590
#7 |
Hi everybody !!
Thanks for the explanation |
#8 |
Hi hm,
I've used an 8" AN (with phase plug- much, much better IMHO than the Fostex FE206e) to good effect, open baffled, with open baffled bass drivers taking over the bass (less efficient than your design of couse). Your design looks like it could be "awesome". How does the 10" compare in upper frequency response, and cone break-up? The manufacturer (forgot his name) claims that it is better all round (this is the one with the phase plug). I did find that the 8" needed to be listened to about 15 degrees off axis. What do you plan? David
D OB G |
#9 |
Yes, I agree also the normal AN 8" seems to be better.
If you look the Data of CommonSense Audio the 10" must be one of the best 10" with high´s. In my SAXOPHON I can listen to the normal 8" on axis, you get the balance to the mids by the construction..
#10 |
two variations more!
| THAT was fast | DragonMaster | Everything Else | 0 | 25th August 2006 05:52 PM |
| help fast ! | v1d9uy | Full Range | 3 | 12th January 2006 10:15 PM |
| need some help with Ohm's law-fast! | mr mojo | Tubes / Valves | 4 | 30th September 2005 10:55 PM |
| i need fast help | shereen | Digital Source | 0 | 21st June 2005 09:14 PM |
| How fast are 'Fast Fuse' and how to identify? | bigpanda | Solid State | 7 | 22nd March 2005 09:00 PM |
| Page generated in 0.12226 seconds (68.01% PHP - 31.99% MySQL) with 10 queries |
