Anybody could recommend small alnico driver with 89-90db efficiency which would comfortable go to around 10-12kHz? I have a nice Expolinar alnico ribbon tweeter and for a quite a bit looking for suitable mid-woofer to cross with 6dB at 10kHz as a helper tweeter . Fostex F120 fits the bill (although I did not hear it) but with its US price of ~$400 a pair just to expensive. The requirement is 89-90 dB, 8ohm ,paper cone ,alnico motor , smooth response and decent price. Thanks, L
#2 |
in that efficiency range there are other types that will provide you with good sounds and efficiency.
others from Fostex, etc, could fit the bill.
stew ☮ -"A sane man in an insane world appears insane." |
#3 |
I dont think I like the membrane on F120A
but FX120 is said to be a nice driver There is also the alltime starr, Tangband W3-871SA(new in black) Or maybe Veravox 5S/X And not to forget the small 50mm Jordan I admit not to have heard any of these and have learned not rely entirely on others judgement |
#4 |
Actually I have never compared but I think I like how alnico drivers sound . I heard a few vintage units and liked their tone. Thy are too efficient for the ribbons I have though. I have Audax 6.5 aerogel right know but they are marginal for the job (although that was original german design some years ago in "Klang & Ton" called ESPRIT ) aerogel cone has a heavy break up modes over 3k and ribbon should be crossed much much higher . I also don't want typical for small woofers forced pumped bass sound (like all those abbys, omegas, totems impressive speakers ) just natural roll off in closed box. Thanks.L
#5 |
Ok, but having never done a comparison a lot of research may be required. Also, again,(a typical lack of information),what's too expensive. or not too expensive?
Is $300 a pair too expensive? or 200? What type of enclosure are you considering? once answered the field narrows considerably, and considerably fast
#6 | |
#7 |
The Diatone P-610 has lower sensitivity than the typical vintage alnicos. See FR graph at http://www.spectrumaudio.de. And probably there are also some smaller radio speakers that are less sensitive, does anybody know how sensitive the oval Sabas are?
#8 |
Ok, $150 a pair for 4"-5" seems reasonable. I'd prefer closed box , something like LS 3/5 with a little higher efficiency .Fostex does look like a perfect candidate .Anybody wants to trade it for a mint pair of FE208 +some cash????Thank you.L
#9 |
limino,
why not build something with the 208's (which ones particularly?). Seems you could have great sound with something you already own! If higher frequecies need a "boost", consider getting a different set of tweeters. Not sure what the real goal is. Is it the physical size of the enclosures needed for the 208s, or the hope for a small monitor for it's own sake? I'm gettin a little confused.
#10 |
As I said I'm looking for a mate to the alnico ribbon tweeters I have for little monito project . They(ribbons) are 89-90 dB so I'm looking for the 4"-5" alnico driver in that range because I'd like to cross ribbons ~10kHz and with drivers bigger than 4"-5" it is not that easy ,and I want reference (or close)upper mid , mid ,low-mid , mid-bass. Thats why I don't want to introduce any port noise nor port bass into the mix .The speakers would be used fullrange in bedroom ,office (or with some woofer cab I may knock-off later to have some bass). I'm using Fostex 208 Sigma (the latest one ) in my main system in front horn as a temporary solution.(augmented by horn tweeter ) I'm not very fond of it although I heard it sounds good in Basszilla with Aurum Cantus G2SI. Everything clear now??.
| Help to choose between Alerion & Pma6 Ob with "Tone Tubby" AlNiCo | HPH | Full Range | 1 | 27th July 2009 08:34 PM |
| ToneTubby 12" AlNiCo OB + Beyma CP380M Horn Project | nullspace | Multi-Way | 6 | 21st April 2009 01:06 AM |
| 1st FR project - TangBand W3-1364 3" Monitor using Dick Smith box | gainphile | Full Range | 3 | 14th November 2008 10:49 AM |
| Old alnico 10" | TroelsM | Multi-Way | 5 | 3rd November 2007 02:55 PM |
| FS 2@ 15" JBL Alnico speakers | kjunom | Swap Meet | 5 | 3rd December 2005 09:39 PM |
| Page generated in 0.30705 seconds (29.77% PHP - 70.23% MySQL) with 10 queries |
