Old 16th May 2007, 03:44 AM   #1
wixy is offline wixy  Australia
Default Made a boo boo when constructing a speaker - will it have much effect?
I recently constructed a speaker (Fostex FE208ESigma cabinet with FE206E driver), and made an error of not placing the driver in the position of absolute centre. It is about 1 - 2 mm off to one side.
What sort of affect (if any) will this have on sound?
Old 16th May 2007, 03:49 AM   #2
Nanook is offline Nanook  Canada
Nanook's Avatar
Default essentially none.
If you can hear a 1 or 2 mm "offset", you hear with the dogs..
stew -"A sane man in an insane world appears insane."
Old 16th May 2007, 03:56 AM   #3
It's probably about as audible as the difference between the loudspeaker playing at 22 deg C ambient temp and 24 deg C.
Old 16th May 2007, 04:24 AM   #4
Theory would say it should sound slightly better
Regards Philip
Old 16th May 2007, 06:53 AM   #5
Hooray! Thanks guys!
Old 16th May 2007, 08:21 AM   #6
Scottmoose's Avatar
I wish I could build well enough to have only a 1-2mm margin of error.
Old 16th May 2007, 10:51 AM   #7
Geoff H is offline Geoff H  Australia
My thoughts exactly. I hope the other side's a mirror image, be a shame to skew the stage of centre.
Well done.
Geoff
Old 16th May 2007, 11:08 AM   #8
AndrewT is online now AndrewT  Scotland
deliberately offsetting the driver from the nearest three edges can deliver a small audible improvement, particularly at the higher frequencies.
Similarly removing the corner at those nearby edges can help the sound. Try a large radius curve or even a chamfer.
regards Andrew T.
Old 16th May 2007, 11:23 AM   #9
jmateus is offline jmateus  United States
jmateus's Avatar
I can't believe it!!!
JLH 2005, Cyrus and so on...
Old 18th May 2007, 10:34 AM   #10
Puffin is offline Puffin  United Kingdom
Wixy. We spoke about the cutting plan. I assume it was all o.k. Got any pics of your speakers ?
Speaker Made of Fire! speekergeek Multi-Way 4 26th November 2006 07:09 AM
Speaker box made from wood esuko Multi-Way 5 22nd March 2006 10:02 AM
do speaker grills effect sound busterno1 Multi-Way 15 28th March 2004 06:14 PM
Page generated in 0.09524 seconds (72.96% PHP - 27.04% MySQL) with 10 queries
