FE 168ESigma ... How much power is too much ????
Old 14th May 2007, 11:09 PM   #1
G.Kennedy is offline G.Kennedy  United States
Default FE 168ESigma ... How much power is too much ????
OK ... I built my BIB's with FE 168ESigmas and am still waiting on my Bottlehead gear to arrive. I was running the BIB's with a 30 watt all in one, but recently acquired two Marantz MA-500 monoblocks.
MA-500's are rated at 125w. So I know I have the power to blow the 168ESigmas as they are rated at 80w.
I stopped in at a local speaker shop and was telling the guy about my set up and his jaw hit the floor when I said I have 125w on a Fostex.
He felt I could blow the coil in a heartbeat ... like ..... instantly.
He recommended adding a 1/2 amp fuse in line on the speaker wire. He also recommended not letting any teenagers who favor rap music near the volume knob.
At reasonable listening levels ... am I going to blow these drivers ... or would it take a slip of the volume knob to make them go bad????
He kind of freaked me out.
Thoughts.
Old 14th May 2007, 11:41 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Some manufacturers recommend an amp that is rated higher than the driver. It gives you headroom for the peaks.
If you run a 50 watt speaker on a 100 watt amp, the coil will tend to slap the back plate and give you warning of impending damage.
If you run a 50 watt speaker on a 10 watt amp and try and squeeze some extra juice from it, you are more likely to damage the driver from that struggling, underpowered and clipping amp than you are from the 100 watter.
In the long run it's up to you. My preference is to use high powered amps and show some restraint.
planet10 needs your help:
Let's help Ruth and Dave
Old 15th May 2007, 03:52 AM   #3
freddi is offline freddi  United States
freddi's Avatar
thanks to efficiency, music not being stuck in one place and probably the suspension, you're doing better than my sim which shows 166 (don't have 168 Sigma T-S handly) reaching 0.6mm xmax at ~ 2/10 watt around 50Hz
http://img89.imageshack.us/img89/762...bexclimcz9.jpg
I ran CH250 on OB with 200W amp with no problem - of course it couldn't really handle much power nor produce any bass but was safe as long as accidents don't occur.
Old 15th May 2007, 06:00 AM   #4
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
you just have to be careful. How dous it sound?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th May 2007, 06:12 AM   #5
Originally posted by Cal Weldon
........you are more likely to damage the driver from that struggling, underpowered and clipping amp than you are from the 100 watter.........
This has always been my take ... clipping is the worst offender.
Originally posted by planet10
you just have to be careful. How does it sound?
dave
I can't imagine it sounding any better than it currently does ... seriously. Of course that is within the limits of my other equipment. Mostly DJ level audio gear.
The speakers just sing. When I turn it up a bit ... they just go louder with no sign of failing.
I guess I just need to watch out for over driving them .... just don't really know where that point is ... and I don't want to find out.
The only thing that sounds bad .... Zepplin. Just sounds harsh ... Everything else... Awesome sounding.
Old 15th May 2007, 10:33 AM   #6
hm is offline hm  Europe
hm's Avatar
Default G.Kennedy
Hello,
"He also recommended not letting any teenagers who favor rap music near the volume knob."
Thatīs important!!
the driver has a Xmax of 1,6 mm, a lot for Fostex.
normally you get around 1 mm stroke by ~ 1 Watt,
thatīs enough, distrotion is rising, have a look and feel it
with your finger at the suspension.
A normal amp has ~ 1 Watt impuls when the knob
shows "10 a clock"
the mechanic end is much earlier, before a driver smashed by watt, never try "12 a clock".
You are the only one how screws the knob!!
http://www.hm-moreart.de
Old 15th May 2007, 12:53 PM   #7
What about putting a 1/2 amp fuse in line on the speaker wire???
Good for accidents?? Detrimental to sound ???
1/2 fuse is awfully thin wire, is i going to create lots of resistance to the amp????
Old 15th May 2007, 01:35 PM   #8
hm's Avatar
"connection terminals are never better than the wire."
also fuses.
I like nothing between driver and amp.
Old 15th May 2007, 07:54 PM   #9
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
That's two of us. Connections are always problematic, so the fewer the better. They only way you're going to blow those drivers is if you go insane on the volume knob, by which point a) you'll probably be deaf, and b) long before you reach it, you'll hear the suspension limiting the travel.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
FE 168ESigma ... How much power is too much ????Hide this!Advertise here!
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 08:38 PM
Fostex 168Esigma vs. Audio Nirvana 6.5 kmj Full Range 43 3rd June 2006 04:14 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 06:49 PM
