Are there any designs out there preferably floorstanding for the 3" Aura ns3?
Steve. http://www.madisound.com/cgi-bin/ind...4.1118&pid=100 |
#2 |
How about this one?
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
#3 |
I designed a MTM MLTL with the Aura NS3-193-8A. I used one of the small High Vi tweeters between the drivers. Using Martin King's spread sheets the MLTL came out to be 42" internal height with a 3.5" x 5.0" cross-sectional area for the insides. The drivers were located at a composite distance of 6.3" from the top while the port was at 41" below the top. The port tube is 1.75" diameter and 4" long for this configuration. Nothing like the bouncing cones of the NS3s as you crank-up the volume. Amazing bass down to near 40 Hz for this small floor standing configuration.
A MTM or bipolar configuration makes sense for these drivers as you achieve a higher sensitivity (low 80's dB SPL) than for a single NS3. A single NS3 with baffle step comp would run into the mid to upper 70's dB SPL so dynamic range would be more limited. |
#4 |
Hi Jim,
Would it be out of the question to post your crossover for this design? |
#5 | |
Enjoy! Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102 |
#6 |
Thank you, sir.
#7 |
Made a pair of these using cardboard and toiletpaper rolls for the ports. They look damn ugly but I'm going to try to pretty them up with some wallpaper. They sound fantastic. I'm rockin' out to a great jazz organ solo as I write this.
I used the Aurasound NT1-204-8D 3/4" instead of the specified tweeter. Madisound helped me with changing some of the crossover values. The required resistor values were hard to find so I bought the closest values I could find. |
#8 |
wow, cardboard! i would imagine that cardboard resonates terribly...
#9 |
#10 |
They actually look awesome!
| Aura Ns4 | inertial | Multi-Way | 3 | 4th June 2009 04:48 PM |
| Aura PSAMP1 | bekim | Solid State | 7 | 18th July 2008 08:45 AM |
| Aura BIB's ??? | Fast1one | Full Range | 36 | 23rd March 2007 09:53 PM |
| Aura NRT18-8 | 95Honda | Subwoofers | 24 | 31st December 2006 01:46 AM |
| Aura Ca-200 / Pa-200 | cdl | Solid State | 8 | 7th October 2003 12:13 AM |
| Page generated in 0.10945 seconds (82.88% PHP - 17.12% MySQL) with 11 queries |
