Old 23rd April 2007, 02:22 AM   #1
aviv007 is offline aviv007  Israel
Default Omega super 3 clone
Hello,
I'm interesting to start a new project -clone of Omega Super 3. Did someone here tried to build this speaker ?
I need all the information i can get,especially about the internal of the cabinet (scheme and damping)...
Aviv
File Type: jpg _xrs_ebony_front_back_revised_small.jpg (17.0 KB, 1654 views)
Old 23rd April 2007, 09:20 AM   #2
frugal-phile(tm)
planet10's Avatar
That os pretty close in shape to Mileva... but Mileva actually uses the height of the cabinet to its advantage instead of just being a bass reflex... i am close to publishing final plans but i could send you the draft ones.
Chris has a pair in his TV/HT room. They work well.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd April 2007, 03:04 PM   #3
Thank you for the response. I saw already this project ,but i'm trying to stay as close to the original one...
Maybe you know ,if the super 3 use the same instruction in the inside of the cabin ?!....
Old 23rd April 2007, 03:14 PM   #4
Godzilla's Avatar
I'm not sure anyone really knows but i think the Super is basically the same DBR eclosure as the recommended box by Fostex with the opening on the back.
Just a guess.
Old 23rd April 2007, 03:28 PM   #5
Scottmoose's Avatar
AFAIK it's just a basic MLTL, with a sand-filled lower chamber. Nothing fancy. All the external dimensions are given on Omega's site, so guesstimating the rest is easy enough.
Old 23rd April 2007, 03:30 PM   #6
chrisb is offline chrisb  Canada
Just a guess.
what the DIY community really needs is a portable ultrasonic scanner - then all the guessing would be over
perhaps CTU has one to spare
Seriously, though I think Louis would suggest (as would Ed Schilling) that there's more inside their boxes than you might think you can "intuitively reverse engineer"
I can confirm that Dave's Mileva design works well, and is a much easier build than a BLH (it also has higher WAF) - a direct comparison to the Frugelhorn will probably take a few days to set up.
Old 23rd April 2007, 03:34 PM   #7
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
dave
on or off topic..........is that beauty named after M. Maric?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 23rd April 2007, 04:37 PM   #8
Just a guess.
Maybe, you have a link for this one ?
Old 23rd April 2007, 04:48 PM   #9
Actually that's a complete fluke - I had to do a quick google on the name myself, after Dave said "that sounds rather Russian" I guess he was geographically close enough.
It actually came about as a sort of acronym - the cabinet is a (folded) Ma$$ Loaded Voigt Pipe - it could have just have easily received a more literal set of vowels (malovo) but that didn't sound quite as poetic. Since the first pair I built were for my wife, the feminine just sounded right.
Now, back to the regularly scheduled program ......
Old 23rd April 2007, 04:52 PM   #10
Godzilla's Avatar
http://www.fostexinternational.com/d...7e_enclrev.pdf
Outside dims are similar and can be modified to be the same as the Omega box as long as you keep the inside volume of the two chambers the same as the recommended box.
So, not the same as the Omega but similar and probably also excellent.
Peace,
Godzilla
PS. Avi, do you take krav mega? I have been doing it the past two years. It makes you into an animal. I love it!
FS: Eminence Omega Pro-15A truenorth Swap Meet 0 29th April 2009 12:53 AM
PA subs using Omega Pro 18's soulfinger Subwoofers 4 28th July 2007 02:03 AM
Omega Grand 6 and which amp? kenscott30 Tubes / Valves 0 20th October 2004 09:46 PM
Best Tweeter for OMEGA PRO 15 ganzonimx Multi-Way 2 29th January 2004 09:46 PM
Eminence Omega p-12A Duo Multi-Way 9 9th January 2003 05:02 PM
Page generated in 0.14370 seconds (68.58% PHP - 31.42% MySQL) with 11 queries
