Old 14th April 2007, 02:41 AM   #1
Default What 12" should I put in
the empty holes here...... Will be buying a couple plate amps. Also what tweeters for top end helper. Thanks.
Old 14th April 2007, 02:44 AM   #2
Default Here is the back
Old 14th April 2007, 02:46 AM   #3
Default with grills
Old 14th April 2007, 03:22 AM   #4
Seems like we would need to know the volume of the bottom chamber and a little something about the other drivers there.
mike
Old 14th April 2007, 03:26 AM   #5
Dimension is 32"x16"x11" - Cabinets are sealed but I can make it ported by cutting a hole rather easily. I am open for anything (inexpensive is even better.) The fullrange drivers are no name vintage alnico Japanese speakers.
Old 14th April 2007, 06:22 AM   #6
djn is offline djn  United States
djn's Avatar
are you putting subs in those lower cabs? What is the range of the top drivers and are they right for OB? I like the looks. Cheers.
Old 14th April 2007, 09:49 AM   #7
Scottmoose's Avatar
Well, this is what you'd get out of an Eminence Beta 12A in that box, with a 4in diameter, 3in long port installed, with it's centre 3in up from the internal base. The Eminence units are very good indeed IMO -loads of excursion, bomb-proof build, and exceptionally well engineered. Not particularly expensive either. Should be pretty easy to XO to the upper dipole unit as they run up a fair way pretty smoothly, and their lower roll-off should match to room-gain nicely. Given their near 100db sensitivity 1w/1m, the plate amps are going to be idling.
As for tweeters, try the Fostex FT17H horn loaded tweeter. Nice unit. Again, not very expensive & the sensitivity is pretty high at nearly 100db 1w / 1m. Better to have a high sensitivity than a low -it's easier to cut things than to boost them.
Old 14th April 2007, 12:48 PM   #8
DJN, the full range are good for around 60hz ~2000. They sound quite nice in OB.
Hey Scott, since the Eminence Beta 12A are so efficient, perhaps I can just put a large choke in them and cross them at ... says 200hz and run them parallel with the fullrangers without plate amp. What do you think.
Old 14th April 2007, 01:30 PM   #9
Scottmoose's Avatar
That's what I'd probably do. Unless you're thinking about going active, I can't see much point in using a plate amp in this case, as we're looking at near 100db efficiency levels for that section.
Old 15th April 2007, 05:55 AM   #10
Though designed for a horn sub I was shocked at how well the Lab12 Generation II from parts express simmed. A little pricey at 175ish dollars but if it actually performed this well...
mike
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 02:34 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 3 2nd January 2007 09:31 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 07:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 09:42 AM
Page generated in 0.11592 seconds (77.61% PHP - 22.39% MySQL) with 11 queries
