#11 |
A lot cheaper (75ish dollars) but looks kind of nice. Selenium 12PWS5-SLF.
mike |
#12 |
Very impressive. I'd want to roll the FR of the LAB12 off though (which is what I did for the Eminence) or the room is going to grab that LF and run with glee.
#13 |
Hi Justpoor, are there any numbers on the back of the drivers? I am surprised they only go to 2 Khz. The cones may be soggy, could be tweaked a bit.
Geoff |
#14 |
Geoff, actually they probably went up to 5~6000 - it was typo.
Scott, How do I tame the 12's sub down to match the fullrange. My fullrange are only 93~94db where the emminence are 98. Thnx. |
#15 |
Add a resistor or LPAD in series with the (bass) driver. Try a 4ohm to start out with & adjust the value to match / taste.
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Charcoal "Supreem" hi-density foam "enclosure" | IG81 | Multi-Way | 0 | 23rd April 2009 01:34 PM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 08:31 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.09105 seconds (60.60% PHP - 39.40% MySQL) with 11 queries |
