Forum Problems If there is a forum related problem please leave a message here so an Admin will see it.
Links to threads not working
Closed Thread
Old 31st July 2013, 10:44 PM   #21
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Hmm, seems fine with FFv22 on OSX. Just checked half a dozen threads with no problems at all.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 1st August 2013, 01:01 AM   #22
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Default Links to threads not working
When I click on links in full-range forum for any thread, I get message "Page not found". I noticed that the links are producing html script that looks inconsistent with the link that appears for example on a google search (which works).
For example a search in google for "Karlsonator diyaudio" will produce this link which works. Karlsonator
But if I go to the full range forum home and click on the Karlsonator thread, I get this link, which appears to be a php script rather than a direct html address. http://www.diyaudio.com/forums/full-...d.php?t=239386 And this does not work, other than to produce this message: "Page not found"
This happens to almost all the links, starting this morning. I am wondering if it is affecting others. I have the problem from Android, iPhone, and also a PC. So it is not the device.
The links to PM's works fine however. I believe it has something to do with the php script not working.
Thanks,
X
Old 1st August 2013, 01:16 AM   #23
Greebster is offline Greebster  United States
Greebster's Avatar
I reported the same thing this morning in another thread,
but it just did it again. Shut down my browser, killed my wifi and started over from scratch. Bingo, but not thoroughly tested with other forums yet. Will add I don't use cookies so I'm always logging in. Not a problem just letting you know
Old 1st August 2013, 01:45 AM   #24
tb46 is offline tb46  United States
Default Forum re-direct errors
I have seen similar problems. Signing in didn't help. Rebooting didn't help.
Here is an example for a re-direct from one forum page to another that does not work:
http://www.diyaudio.com/forums/full-...=239338&page=8
Error: HTTP 404 Not Found
Going from the same forum page to the same destination by editing the URL (changing ...-6.html into ...-8.html) works fine:
Mini Karlsonator (0.53X) with Dual TC9FD's
Oliver
Old 1st August 2013, 01:53 AM   #25
just a guy is offline just a guy  Canada
Edit the url and it will work. For example here's a link that will not work. (I added a couple of spaces so it will display the whole thing instead of truncating.)
ht tp://www.diyaudio .com/forums/subwoofers/showthread.php?t=240102&page=2
See the subwoofers/ part? That's the subforum the thread is located in. Delete that so it looks like this:
h ttp://www.diyaudio .com/forums/showthread.php?t=240102&page=2
...and then hit enter and it works.
Pano posted in the other thread that the url is doubling up but that's not the issue I'm seeing.
Old 1st August 2013, 02:11 AM   #26
Pano is online now Pano  United States
Pano's Avatar
It's doubling for me if the link is to a thread, but not to a post. Strange.
Old 1st August 2013, 03:12 AM   #27
nottolkien is offline nottolkien  United States
Default links: threads and their page numbers Broken
I think you are prolly aware by now that links aren't working. Just wanted to say that this includes the links given for various pages of a thread. Starting with a google search might land you on a particular page of a thread, but when you click the link for the next page at the bottom of the page you just read, a message appears; "page not found", if I remember correctly. Thank you for your time in this. - Aubrey
Old 1st August 2013, 04:59 AM   #28
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
Sadly, I'm just about to get on a 7 hour train ride. I will get on to this as soon as I have a connection and try to work it out. Sounds like something weird to do with dates?
Old 1st August 2013, 05:03 AM   #29
Jason's Avatar
I've just restarted Apache and MySQL, let's see if that makes any difference.
Old 1st August 2013, 05:26 AM   #30
bk856er is offline bk856er  United States
bk856er's Avatar
Default "page not found" beyond top level
All day today 7/31.
Can't follow links/threads past the top level in most forum areas.
Seems others have the same issue.
Need my daily diyA fix!!!
BK
Closed Thread
Links to threads not workingHide this!Advertise here!
Great Links lawbadman Everything Else 5 29th August 2007 07:13 AM
WTB Krell KSA Mk2- working or non working Jozua Swap Meet 0 20th March 2006 11:14 AM
Links in e-mails not working Devil_H@ck Forum Problems 2 2nd June 2004 03:59 PM
need for links Guss The Lounge 2 6th September 2003 04:46 PM
