Forum Problems If there is a forum related problem please leave a message here so an Admin will see it.
icons stopped working
Old 16th July 2012, 07:14 PM   #1
DF96 is offline DF96  England
Default icons stopped working
The small icons in the Quick Reply box have stopped working. I don't think I have done anything, although MS or Firefox may have carried out an automatic update. Any ideas?
Old 17th July 2012, 10:16 AM   #2
I have also noticed that when posting I now always get the extra page telling me what is happening, instead of simply refreshing the thread with my post added. Not sure if these are related.
Another forum I use which has the same underlying software still works OK, so something has changed at DIYaudio.
Old 17th July 2012, 10:36 AM   #3
Another problem. If I try to edit a post then I can make changes but then not save the result because the Save icon doesn't work either.
Is this a Java problem? I updated my Java yesterday because Firefox told me it was out of date but this has not fixed the problem.
Old 17th July 2012, 11:28 AM   #4
Mooly's Avatar
You should be able to check Java here, it will tell you if the correct version is installed.
Verify Java Version
I haven't noticed anything different and I always see a page that says something like "thank you for posting". I always have done.
Old 17th July 2012, 11:30 AM   #5
Mooly's Avatar
Lol... and this time I didn't ! Taken straight to the post.
Old 17th July 2012, 11:34 AM   #6
Mooly's Avatar
Which now has done !
Funny how you notice things. The image attached went straight to the "main page" and didn't show as uploaded in the small pop up window which I normally then have to close...
Dunno... maybe some things are different.
Old 17th July 2012, 11:57 AM   #7
Just checked Java at that link you gave. It says version 7 update 5, which is the current recommended version.
Maybe I will try logging out, or deleting DIYaudio cookies.
Old 17th July 2012, 12:02 PM   #8
Osvaldo de Banfield is online now Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
The forum is working properly for me (Win XP +Chrome). TNX.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 17th July 2012, 12:07 PM   #9
Mooly's Avatar
Worth a try. Also maybe delete all temp Internet files that can be deleted. I only use IE so don't know how and where other browsers store the info.
Old 17th July 2012, 12:41 PM   #10
Logging out doesn't fix it, neither does deleting cookies. Incidentally, when I log out it says that cookies have been cleared but Firefox told me they were still there so I deleted them manually.
icons stopped workingHide this!Advertise here!
Amp Stopped Working twhittle14 Car Audio 30 25th November 2012 04:33 PM
Sub Stopped Working cmcimino Car Audio 4 27th June 2010 04:14 PM
el84 1 channel stopped working help eddiedavies Tubes / Valves 5 2nd April 2007 11:32 AM
pinnacle 850 stopped working jamesj2 Multi-Way 1 14th February 2005 09:48 AM
Copyright ©1999-2017 diyAudio
