Forum Problems If there is a forum related problem please leave a message here so an Admin will see it.
Not possible to navigate away from a discussion when you have submitted an answer
Old 1st June 2011, 07:38 PM   #1
Elvee is offline Elvee  Belgium
Elvee's Avatar
Default Not possible to navigate away from a discussion when you have submitted an answer
This problem has been ongoing for some weeks now.
When you post an answer to a discussion and try to go back, you receive a prompt asking if you want to resend the information or cancel, and there is no way you can ignore it as before: either you use other means to go where you want to go, or you resubmit your post.
The problem is browser-independent, I have computers under IE and others working with Mozilla, but the behavior remains the same.
And considering the number of duplicate posts, I'm certainly not alone in this case.
Edit:
I tried to navigate back from this message and it *#{ did it again
Old 2nd June 2011, 03:15 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
testing.
Not happening here but I will bring it to the attention of the head cheese.
planet10 needs your help:
Let's help Ruth and Dave
Old 2nd June 2011, 03:22 PM   #3
Chris Daly is offline Chris Daly  Australia
The mistake is going back -Instead of going back, go to home located in top the far left hand side in the blue headings.
If indeed you need to edit your post use the edit function, so don't use back go home first and think of ET ... home
Old 2nd June 2011, 05:40 PM   #4
Elvee's Avatar
Let us try:
Old 2nd June 2011, 05:45 PM   #5
Elvee's Avatar
Doesn't work either, same prompt:
Old 2nd June 2011, 06:33 PM   #6
macboy is offline macboy  Canada
Click and hold the back button. You will get a list of the recently viewed pages. Select the one named after the thread, which should appear before/below the one called "diyAudio - Reply to Topic"...
This works in IE and FireFox.
Old 2nd June 2011, 06:41 PM   #7
Pano is online now Pano  United States
Pano's Avatar
Going back after posting is the problem. You would be going back to the form where you posted your answer. Of course your browser thinks that's a bit hinky.
You should be taken back to the thread by the forum server after you post. That is normal procedure. Is that not happening for you? Is that why you are suing the back button?
Take the Speaker Voltage Test!
Old 2nd June 2011, 07:27 PM   #8
Elvee's Avatar
Yeah I know, but I instinctively hit the back button, and it used to work, maybe with a message, but another click on back, and that was it.
Now I have to get used to this on DIYaudio, on other sites it still works the old, normal way.
That's a minor annoyance, but if it could be fixed, it would be nice.
Old 2nd June 2011, 08:51 PM   #9
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
After you make a post the normal forum behaviour is to land you back into the discussion you posted in, looking at the post you just made. The software goes thru a couple redirects to get you back, perhaps you are just not patient enuff, or if it takes forever perhaps some time for some computer maintenance.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd June 2011, 06:37 AM   #10
Elvee's Avatar
That's what it does, no problems with that.
But then, I remain stuck, and I cannot use the back button.
Not possible to navigate away from a discussion when you have submitted an answerHide this!Advertise here!
Submitted for your (dis) approval, OTL, Autobias Inv. Futterman Alastair E Tubes / Valves 21 4th February 2014 01:04 AM
No answer Antoni D The Lounge 2 13th February 2011 06:19 AM
Submitted for your amusement. hags Everything Else 30 12th October 2007 09:11 PM
need a tech to answer this one pks71 Car Audio 1 19th November 2004 11:50 AM
Copyright ©1999-2017 diyAudio
