Forum Problems If there is a forum related problem please leave a message here so an Admin will see it.
IE 8 problems
IE 8 problems
Old 9th August 2010, 05:08 AM   #1
lgreen is offline lgreen  United States
lgreen's Avatar
Default IE 8 problems
When I login to this site with Internet Explorer 8 and check "stay logged in" (or don't check it), the site checks me in successfully but then does not display my username; it still shows that there is no one logged in and has blanks for the username and password. But in fact I'm logged in which can be seen when-
-I refresh.
-I click a link
In these cases my info comes up and then it seems that I'm in.
Also, if I try to post a new thread using IE 8, it seems to work fine until I hit "submit" and then the page reloads itself endlessly. On and on and on. I have to click a link or hit "Home" to get the refreshing to stop.
Is it just me? These two issues happen with 3 computers using IE 8, some on Win XP and some on Vista. And this happens every single time.
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Old 10th August 2010, 02:30 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
IE 8 problems
I haven't used IE for a few years so not certain. Why not try and different browser? Is IE still up to today's standards?
planet10 needs your help:
Let's help Ruth and Dave
Old 10th August 2010, 02:54 PM   #3
wakibaki is offline wakibaki  United Kingdom
Banned
I normally use google Chrome now 'cause I found IE8 a bit slow, but I just tried IE8 and I can't get it to replicate your problem, it works fine for me. The computer is running XP SP3
w
Old 10th August 2010, 03:44 PM   #4
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Try updating or reinstalling Java.
Old 11th August 2010, 08:19 PM   #5
JBdV is offline JBdV  Netherlands
IE 8 problems
I have the same problem
Old 12th August 2010, 04:08 AM   #6
lgreen's Avatar
My issues should be pretty common, as indicated by JBdV, has no one else experienced them?
I have the latest Java and update all the time (auto update).
Yes I have tried other browsers and they do not have the same problems. But I'd like to get the few PCs I use on IE8 to work!
Old 14th August 2010, 02:50 PM   #7
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
IE 8 problems
Actually we just had someone write to the helpdesk with this problem as well. Nothing major has changed on the site in a long time, and I don't get any problem on my IE8.
I'm using 8.0.7600.16385 on Win 7 x64.
If you could kindly contribute your exact setup it would be very much appreciated.
Old 14th August 2010, 09:49 PM   #8
IE 8 problems
A day later everything works fine, so maybe an additional reboot helps
Old 14th August 2010, 10:10 PM   #9
dfidler is offline dfidler  United Kingdom
dfidler's Avatar
I've seen this issue with a couple of my board members as well. It usually occurred after I'd upgraded the software or had made changes to the cookie settings for vB.
In almost all cases, nuking the browser cache and restarting the browser worked.
I say 'almost all' because I had one user who kept having this issue intermittently. It would work, fail after a few months, work, etc.
The problem was fixed when they gave up on IE and, eventually, moved back to IE after buying a new laptop (aka - a new windows install).
IE 8 problemsHide this!Advertise here!
MiniWatt N3 problems, oscillation thumping and RF/motor problems. Destroyer OS Tubes / Valves 18 6th July 2010 01:14 AM
Problems Markz66mustang Car Audio 14 28th December 2004 07:04 AM
will this cause problems? slackerbob Multi-Way 9 29th November 2003 08:25 PM
