Go Back   Home > Forums > Site > Forum Problems
Forum Problems If there is a forum related problem please leave a message here so an Admin will see it.
Old 5th February 2009, 01:27 AM   #1
saj888 is offline saj888  Trinidad and Tobago
Default crest 200 series
I have repaired thousands of pro audio over 20 years. Power amps especially. Crown, qsc, crest etc. I presently have 12 Crest pro 200 series amps in the shop. From 5200 to 9200. One circuit board, 90% surface mount, very high voltage switching power supply. The entire amp has to be removed from the chassis. Does anyone in the world know of a systematic troubleshooting method to repair these contraptions?
Presently it seems like I have to randomly test parts like an amateur tech. Or a crazy tech.
Anyone??
Old 17th February 2009, 02:44 PM   #2
tebbi is offline tebbi  Germany
Default crest
hey,
is it a switching power supply?
Try to put a bulb (or two, at a symetric supply) on the power rail to test it.
Its tricky but it works
round about 50Watts are enough.
I repair since 1984,and often it was a good helper to fix some circutry problems.Most of them switching problems in the power supply.
Greeting
Stephan
Old 18th February 2009, 02:08 AM   #3
Default Switching power supply amps.
Are you serious? We are not talking basic troubleshooting here. Im talking about advanced pro audio troubleshooting techniques. I have already installed 3 switchable bulbs on my 10 amp variac, which came with a built in voltmeter and amp meter. Try downloading a QSC plx 3002 schematic from the qsc site. You would have an idea of what im talking about.
Thanks.
Old 20th February 2009, 01:40 AM   #4
Hallo,
I have seen it,and find it looks a littlebit like a Philips schematic.Most of the technicans mean you can build two television with one.
Okay, what is the main problem (defect)of the most of your amps?
You have the advantage to have a schematic.
Or did you think there is a bug inside the concept?
Some circutdesigns (SMD) are working on the temperature limit.There are a lot of measuring points you can use.
crest 901 series sakis Solid State 0 16th July 2009 04:13 PM
Crest 6A Regulated PSU imix500 Swap Meet 6 10th February 2009 03:36 AM
crest 6001 ouij67 Solid State 0 12th January 2009 01:50 AM
Crest CA-4 schematics - Anyone? Zero Cool Solid State 0 14th January 2007 02:01 AM
Crest SK series Amp Transformer for sale on ebay... imix500 Swap Meet 3 15th January 2006 12:05 AM
Page generated in 0.07407 seconds (76.10% PHP - 23.90% MySQL) with 10 queries
