Acoustic tile questions...
In the pro world, usually wall treatments are rigid fiberglass panels that are fabric covered. Some of this is made ahead of time, some on site, due to size/site conditions. I have used/seen contact spray, staples & hot glue used to adhere the fabric & Velcro® for holding the panels on the wall. The panels are light & the Velcro® gives you some leeway in placement & alignment.
Armstrong is the big player in ceiling tiles. Almost the only player!
Remember, this helps tighten the room, clear up some issues. Low frequencies are tough & require more work than highs. Also, as sound travels like light, you can often get away with panels staggered across from each other. They do not need to cover the entire wall, although that is better.
Take a look @ vocal recording booth treatments, they come in kits & are quite effective, too.
Good links above for info.
These folks are the best in the business & have been around for years.
http://www.rpginc.com/proaudio/proaudio-products.htm
More:
http://www.auralex.com/
http://www.diynetwork.com/diy/hi_family_room/article/0,2037,DIY_13912_3471072,00.html
