How does an attenuator impact on a system ? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 10th April 2007, 01:37 PM   #1
Question How does an attenuator impact on a system ?
Hey all.
Wasn't really sure where to post, so I figured here's as good a place as any.
I understand that basic concepts of impedence, and that you want the ouput impedence of the source to be significantly lower than the input impedence of the next component.
Now, suppose I have a preamp with an output impedence of 100 ohms, and an amplifier with an imput impedence of 100k ohms. Then, I whack a 100k potentiometer between them. Since the pot is in parrallel with the two devices, have I essentially turned that 100 ohm into 99.9 ohm (or unchanged), and the 100k ohm into 50k (halved it !)?
What's the mathematics in chosing a pot given an output and input load ?
Old 10th April 2007, 01:49 PM   #2
Did it Himself
richie00boy's Avatar
Think about where the pot wiper is, then examine the various impedances each side of the wiper to arrive at the conclusion.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 10th April 2007, 02:37 PM   #3
jan.didden's Avatar
Default Re: How does an attenuator impact on a system ?
Originally posted by lordvader
Hey all.
Yes, in the max level setting. As Richieboy noted, the values vary with the wiper setting. Assuming that the Zout of the source and the Zin of the amp are linear (resistive), not varying with level, freq, etc (and in a competently designed component that will be the case), the only effect of those varying impedances will be that the attenuation is not exactly what you would calculate with zero Zout and infinite Zin.
For example, with zero Zout and infinite Zin, if you put the wiper half way, you get exactly half the level. With 100Ohms Zout and 100k Zin, that will be a bit less than half level, but this is a non-issue, if you pot is at least 10 times the Zout, and not more than the Zin, preferably lower. In your case, 10 to 20k pot would be OK.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 10th April 2007, 03:33 PM   #4
I would select a pot at or below Zin/10.
This keeps the source impedance presented to the following amp @ <Zin/40.
Take your Zin=100k and pot=10k then Rs<=2k5, but this varies down to near 0r0. The variation in source resistance causes changes in the power amplifier.
As usual, the lower the Rs, the less the power amp is affected.
If your pre-amp/source can drive a lower value pot then go down to Zin/100 i.e. 1k0 and Rs then varies from 0r0 to 250r (much better).
Caution:- a 1k0 load driven at upto 2V requires the source to send peak currents upto 3mApk. Some (many?) sources will not play well at this level of output current.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th April 2007, 12:25 AM   #5
Thanks for the info.
But how does a pot of Zin/10 present an impedence of Zin/40 (your Rs value) to the preamp ?
Old 11th April 2007, 07:26 AM   #6
the source resistance seen by the receiver depends on the position of the pot wiper.
when at the bottom (=zero sound) Rs=0
when at the top (=zero attenuation) Rs=potvalue//Rs source~=Rs source.
When between these positions the Rupper and Rlower set the source resistance.
If the wiper is in between then the receiver sees Rupper and Rlower, effectively in parallel.
at -20db Rupper =10k-1k=9k, Rlower =1k,
Rs=1k//[9k+Rs source]~=900r (if Rs source=100r, Zin=100k, then attenuation = -20.16db).
As the wiper moves towards max attenuation, Rs falls.
As the wiper moves towards -6db Rs rises.
At -6db position, Rupper=Rlower =5k. Rs=5k//[5k+Rs source]~5k//5k1=2k52, or just about Zin/40. (attenuation = -6.32db)
as the wiper moves from -6db to -0db Rs falls again.
Note that Rs is seen by the amplifier and the HF filter that should be fitted will vary in turn over frequency as Rs varies. -0db and -60db present a low Rs and the filter is set very high letting through a lot of unecessary crud. At -6db, the high Rs sets the frequency at it's lowest and chops off the upper audio band. The pot and amplifier MUST be designed together to get a passive volume control to work near effectively.
Most users just fit to the Zin/10 formula and usually get it wrong i.e. variable filter with volume. For those who insist on using DC coupled amplifiers then there is the variable output offset to contend with (a DC servo is designed to compensate for amplifier offset, NOT for variable input offset).
regards Andrew T.
Old 11th April 2007, 12:48 PM   #7
That's what I wanted !!!
Now just need to chew on it for a little, and I'll be fine (too tired right now !)
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 10:16 AM
6x ladder attenuator on active system aaronboumans Pass Labs 1 24th February 2005 08:56 AM
need more impact DIYGuy Multi-Way 7 10th February 2005 07:01 AM
Sonic Impact powered office system tleonard Full Range 4 10th January 2005 03:19 AM
Copyright 1999-2017 diyAudio
