Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
What solvent for best removal of solder flux?
Old 10th April 2007, 11:04 AM   #1
space is offline space  Norway
Default What solvent for best removal of solder flux?
I've finished soldering an Amp32 (small 2 sided amp with mostly SMD-components) from www.41hz.com and now want to remove solder flux. I'm a chem. eng. and have a small lab with some different solvents avalible. Which of these would be best?
Methanol (CH3OH), Ethanol (CH3CH2OH), Isopropyl alcohol (CHCHOHCH3), dichloromethane (CH2Cl2), acetonirtrile (CH3CN)
I've also got an ultrasonic cleaner (with heating if needed) and are considering using it, or should I just use a soft brush?
I've used a cheap solder with flux inside and don't know what type it would be. I've also used small amount of flux made for copper plumbing containing zinkchloride as the active ingredient. It is stated as partially soluble in water.
space
Old 10th April 2007, 12:57 PM   #2
Conrad Hoffman is offline Conrad Hoffman  United States
Not sure if there's a best, but I use isopropyl. You'll also want to use soap and water with a toothbrush because of the acid flux, and the whole thing should be given a good rinse in DI water when done. The usual test is that the water should run off in sheets, not drops, if the surface is truly clean. The ultrasonic is good, but heavier deposits will go faster with mechanical means like the toothbrush ;-) Watch out for unsealed pots- no solvents or water there, and styrene capacitors- don't use anything that will penetrate the styrene and raise the DF or short out the cap!
Old 10th April 2007, 05:07 PM   #3
Pjotr is offline Pjotr
Pjotr's Avatar
HI,
If all components are washable you can put your board in the dishwasher to clean it. Really, no joke, many smaller professional PCB assembly shops do it that way.
Isopropropanol and a sturdy brush is a good way. For the tough flux residues I use methylene chloride. But be careful with that, most components can stand it but not all plastics will do
Old 10th April 2007, 05:41 PM   #4
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
I wouldn't recommend Iso-alcohol if the board has solder-masking. It can cause a haze. If it's a bare bones board though then its ok.
Old 10th April 2007, 07:07 PM   #5
Pjotr's Avatar
True, some solder masks have that habit, they stand only water and soap. But with a good well cured solder mask it is no problem.
Old 13th April 2007, 04:17 AM   #6
XEAGLEKEEPER is offline XEAGLEKEEPER  United States
XEAGLEKEEPER's Avatar
Dont laugh.I use Everclear 98proof grain alcohol(ethyl alcohol) and a trimmed acid brush then a rinse down with circuit cleaner.
Dave
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 13th April 2007, 05:58 AM   #7
TwoSpoons is offline TwoSpoons  New Zealand
TwoSpoons's Avatar
Electrolube FLU Fluxclene is the best I've ever used. Comes in a handy spray can.
Old 13th April 2007, 06:09 AM   #8
I've cleaned my circuit board now using isopropyl alcohol heated to about 40-50 deg. C in an ultrasonic cleaner. Left the board in for about 10-15 min. Rinsed it of with fresh isopropyl alcohol and dried it using compressed air. Seem to have worked very well.
Thanks for all your inputs!
space
Old 13th April 2007, 03:32 PM   #9
FYI . Plumbers flux is corrosive to electronics.But your alcohol bath has probably nuetralize that issue.
Dave
Old 18th April 2007, 04:31 AM   #10
gmphadte is offline gmphadte  India
The easiest available flux remover is petrol used in cars but how it behaves with the solder mask, no idea.
Gajanan Phadte
What solvent for best removal of solder flux?Hide this!Advertise here!
Solder, Flux, and Cleaning Discussion Hartono Parts 20 11th December 2013 12:43 PM
Solvent needed hewlew1 Multi-Way 1 27th March 2007 04:56 AM
How to use liquid solder flux Stuey Equipment & Tools 3 23rd March 2007 11:46 PM
Solvent? Zen Mod Full Range 1 18th April 2006 06:56 AM
Solvent washing PCB boards eeka chu Solid State 34 19th May 2004 05:46 PM
