Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
soldering an XLR to Cinch adaptor
Old 6th April 2007, 10:44 AM   #1
Bassterror is offline Bassterror  Germany
Default soldering an XLR to Cinch adaptor
Hi
I've got a PA Amp here, wich has symmetrical inputs, but i have only unbalanced sources, cinch.
How do I connect to to wires from the cinch plug to the XLR?
I whould do it this way:
Pin3 -> outer conductor of the cinch cable
Pin2 -> inner conductor of the cinch cable
Pin1 -> not connected
OK?
greetings,
Stephan
Old 6th April 2007, 10:57 PM   #2
Burnedfingers is offline Burnedfingers  United States
Cinch plug also called RCA PLUG.
Connect pin 1 and pin 3 to the outside. Connect pin 2 to the inner or tip.
Note* There is a ready made adapter that will mate a RCA to XLR connector that could also be purchased. These are available in either male or female RCA.
Old 9th April 2007, 10:29 AM   #3
Yes, i know. But i forgot to order...
Right now pin1 is unconnected and it works fine
Old 9th April 2007, 10:49 AM   #4
leaving pin1 from the balanced transmitter can cause the transmitter to perform badly.
It would be better to make the cable universal by connecting pin1 to pin3.
Even better is substituting a dummy load between pin1 and pin3 to match the requirements that the transmitter is expecting to see. This last suggestion is not universal.
Then listen to the 3 options.
regards Andrew T.
soldering an XLR to Cinch adaptorHide this!Advertise here!
FS: Cinch plugs dagney2000 Swap Meet 1 17th June 2008 09:20 AM
Where can I get a mini din to rca adaptor? yellow95 Solid State 2 21st November 2006 01:02 AM
Using 8.4V AC adaptor instead of 7.4V HouseMachine Parts 5 8th June 2006 02:44 PM
Using a Nintendo adaptor ChesterFuzzin' Multi-Way 13 24th March 2004 10:07 PM
mini din to rca adaptor yellow95 Multi-Way 0 27th December 2001 05:06 PM
