| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
how do I copy (or export) a view from Win isd pro to IrfanView? I want to post some speaker graphs from isd on this Forum.
regards Andrew T. |
#2 |
Ctrl+Print screen - then paste into MS Paint and save as a jpg - actually Gifs or png's are better for lines.
There are a few freeware programs (printkey 2000?) that simplify this process, but all are annoying in some manner or another.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
I don't have pro but I recall the free version having a 'copy' function where the window in the forefront is copied. I forget if it was a right click or a menu bar function (I'm on my work laptop now)
-then paste into irfanview?
Crazy Yankee. |
#4 |
CRTL+Print screen does not copy. When I pasted, the previous copy was still in memory. Isd does not have copy nor export in the drop down menus. Can anyone else give me some pointers. I have seen what looks like isd graphs so it must be possible.
regards Andrew T. |
#5 |
Alt + PrtScr
Crazy Yankee. |
#6 |
irfanview is a viewer, not an editor, as far as I know, so try using paint.
I use standard windows printscreen (either Alt+ or Ctrl+) and MS paint all of the time, so either WinISD modifies printscreen behavior.... one potential source of error is how you paste - if you use ctrl+v it may be the issue - use the edit-paste from the menu. google for screen capture tutorials and perhaps they will explain it better.
#7 | |
Alternatively, open Irfanview, select 'capture' in the 'options' menu, set what defaults you want to use followed by 'start'. Then you can use CTRL+F11 to directly copy and paste into Irfanview. |
#8 |
Hi all,
got it. print screen (no other keys) re-fills the memory. and then pastes into IV. IrfanView is a lot more than a viewer. I have only just started using it in the last month. Brilliant for rescaling, cropping, compressing and emailing in umpteen formats.
regards Andrew T. |
#9 |
I don't know about WinISD Pro, but in WinISD beta, all you have to do is right-click on the graph, and a dialog box appears which says,
"Export Picture To Clipboard". Then you call up Irfan view, click Edit-Paste, and paste it in. Then click the "maximize" box at the top twice so all of Irfan view is visible. This has the advantage of printing ONLY the graph, not the surrounding areas, if that what you want. A similar thing can be done with XnView, another excellent graphic viewer/manipulator similar to IrfanView, (everyone likes one or the other-they're both great).
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#10 |
XnView lover here too
XnView has a screen capture funtion as well, if you want to grab more than one box at a time. |
| WINisd Help... | jakelm3075 | Subwoofers | 6 | 10th May 2006 01:54 PM |
| Winisd sub ??? | vetkilr | Subwoofers | 5 | 14th February 2006 12:15 AM |
| Help with WinISD and XLS 12 | Glen1 | Subwoofers | 19 | 6th December 2005 02:11 PM |
| WinISD. HELP!!!!!!!!!!!!!!!!! | Dannyball | Everything Else | 6 | 30th May 2004 04:24 PM |
| beyond winisd.... | ChesterFuzzin' | Multi-Way | 1 | 9th January 2003 03:06 AM |
| Page generated in 0.10373 seconds (79.50% PHP - 20.50% MySQL) with 11 queries |
