Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th March 2007, 03:28 PM   #1
beerman is offline beerman  United States
Default Marantz SR-840 won't turn on without tilting up at 90 degrees
Marantz SR-840, just recent enough to have a dedicated CD input, though it's as old as the hills. Bought it for $25 at a pawn shop in 1995. I've gotten my money's worth, that much is certain.
Touching the power button only turns the unit off, you need to touch a source button to turn it on.
It doesn't want to power on. Hasn't for two years now. The front panel (where the station tuning appears) is all lit up. It flickers when I try to power it on.
I can hear something underneath the speaker terminals click twice when I touch a front panel button. If I hold the unit up at a 90 degree angle it clicks on fine.
Is this just a worn relay? Where could I pick up a replacement?
Got Bass?
Old 29th March 2007, 07:45 PM   #2
XEAGLEKEEPER's Avatar
Or possibly a loose connector or dirty connector on the front panels PC board or main PCboard.Or possible hairline crack on the board or a cold solder joint. With the cover removed take a non-metallic(wood or plastic)probe and lightly rake it across the board,around connectors etc. to try and locate intermittent connection.
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
benefits of tilting back floorstanders? dublin78 Multi-Way 2 14th November 2006 02:25 AM
audibility of full 360 degrees phase shift mazurek Multi-Way 3 14th January 2006 10:09 PM
mj15003 running at 80 degrees sunrise Solid State 17 27th July 2005 06:58 PM
Is 50 degrees C too hot? rdf Tubes / Valves 4 6th July 2004 03:23 AM
How can I reduce mechanical turn on and turn off noise? soundNERD Chip Amps 8 28th October 2003 01:43 AM
Page generated in 0.07670 seconds (71.53% PHP - 28.47% MySQL) with 10 queries
