Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th March 2007, 01:42 PM   #1
cpemma is offline cpemma  United Kingdom
Default Thoughts on desoldering braid
For donkey's years I've had the same spool of the Servisol Soldamop braid, worked very well, no problem removing the solder holding components to the point where they'd drop out of the board. A few weeks ago I replaced it with a new spool and found it rubbish, it just doesn't wick up the solder so successfully. Is this the new, improved, colophony-free, healthy flux or do I just have a bad batch?
I'm tempted to invest in a sucker.
Old 29th March 2007, 02:37 PM   #2
Stocker is offline Stocker  United States
Have you tried a higher temperature? also, and this really is sub-optimal, with some braided wicks you need to have a small drop of fresh solder on the iron tip to get the solder hot enough to go to the wick.
Perhaps the copper is the wrong gauge for you, also. dunno if there is a difference. Or it could be oxidezed beyond what the flux can handle. tried using a separate liquid or paste flux with your new braid?
Jesus loves you.
Old 29th March 2007, 07:31 PM   #3
XEAGLEKEEPER's Avatar
The problem is your older solderwick had a better quality rosin impregnate.This newer cr*p is ROHS compliant.But it will work with a little dab of flux.
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Tinned copper braid. AndrewGM Solid State 2 8th October 2008 04:22 PM
Japanese kumihimo braid for CAT5-cables. Bonicon Everything Else 1 27th July 2006 09:46 AM
desoldering station audio-kraut Equipment & Tools 1 13th June 2005 10:45 AM
How to braid Cables (Configurations) Rarkov Everything Else 9 7th June 2004 01:12 PM
Hot air tip- Desoldering SMT parts Dave Everything Else 10 1st February 2003 12:44 AM
Page generated in 0.07642 seconds (68.95% PHP - 31.05% MySQL) with 10 queries
