| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hello All
A friend was here the other day and the subject of small batteries came up when I was busy changing the mouse batteries (no, not the Duracell Bunny's). Anyway, this friend can usually be relied on not to talk rubbish and he asked me if I knew that one could re-charge small batteries marked NON-RECHARGEABLE' . I obviously have never tried it as I'm heeding the warning 'MAY EXPLODE OR LEAK IF RE-CHARGED'. Well, I'm in a bit of a fix tonight. Both garagedoors' remotes' batteries are flat and the shops are shut. The battery fitted to the remote is a Super Alkaline 23A?? 12V battery. I have 2 regulated powersupplies here and can easily dial-up 12V but I'm worried I'll zonk the remote. The door-opener has a manual release but because a special lever is fitted to enable the doors to open to a certain height, this facility is very difficult to operate. Any ideas, guys? Can't leave my car outside as prowlers are around. bulgin |
#2 |
There were articles in some magazines : possible but with a lot of caution. It needs special chargers. Not to do in a hurry wih régulated power supplies.
#3 |
Thanks forr
It's 23.45pm here in Cape Town and I guess I've got a long night sitting in my car outside with a dachshund for company.Regards bulgin |
#4 |
The older type (don't know exactly, some Mn...) could be charged,
I saw the russians on a ship charge and recharge them with ordinary power supply but never attempt to charge the alkalines Gajanan Phadte |
#5 |
I recharged alkalines several times (by misake) in a NiMH charger. It worked Then one cell popped and killed the charger.
Take the Speaker Voltage Test! |
#6 |
I've heard that alkalines can be charged several times- but they could explode at any time during charge. Whenever I heard that, I also heard that they take progressively less charge each time you do it. Not really worth it, in my opinion.
#7 |
I wouldn't call this recharging - regenerating would be a better description.
It works best if they are only partially discharged like down to 70%. It doesn't work as good as charging an accu but you can stretch the lifespan of alkalines significantly. And yes it should be done only with small cells as a professor of the Swiss Federal Polytechnic institute once suggested. I assume that the main rasons for this are: If they burst the damage is smaller with smaller cells and they are less likely to burst from the beginning because they have a better volume-to-surface ratio and thus better heat transfer to the environment. This is the web - page of the aforementioned professor but in German only unfortunately: http://www2.ife.ee.ethz.ch/~zinniker/batak/index.html Regards Charles P.S.: Bulgin might have to get a new battery or sleep in his car for another night. In which part of Cape Town are you living BTW ? |
#8 |
Magneto the Gravity Man
I have often put non-rechargeable cells in a charger and also zapped cells with a car battery...
BUT... Only for a few seconds at a time!!! This is usually enough to get whatever it was working for the required time. This has been with zinc/carbon, lithium and alcaline. Andy PS..my local store sells chargers .............
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#9 |
Did it Himself
Yes you can recharge non-rechargeables, but it doesn't work very well if they are less than about half full. The technique is called periodic current reversal, and is basically an AC waveform. It's also a slow time method.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#10 |
There were articles in Elektor and EW+WW describing circuits to do this.
Yes, they did indeed suggest alternating charge- and discharge- pulses. Regards Charles |
| How to run an AC mic pre from batteries | oaks | Power Supplies | 6 | 17th October 2009 06:02 AM |
| GC and batteries psu | Ilianh | Chip Amps | 40 | 5th October 2009 01:30 PM |
| STK4141 on batteries | Zoodle | Chip Amps | 17 | 12th July 2009 11:23 AM |
| SLA batteries for UcD amp PS | Paul Ebert | Class D | 0 | 16th November 2004 04:53 PM |
| 3 pin li-ion batteries | Holger Barske | Parts | 1 | 12th May 2004 07:54 PM |
| Page generated in 0.10720 seconds (80.16% PHP - 19.84% MySQL) with 10 queries |
