| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have no option but to concede defeat.
Some math wiz here that can explain what "A//B" is? It is supposed to means A divided by B in parallel. The real question for me is, how do I type it in my graphing calculator? |
#2 | |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 | |
Thinking about it, I'm not quite sure where I got what I wrote in my original post. I blame tired head and eyes after hours of reading and re-reading. |
#4 |
Solved it.
X=1/((1/A)+(1/B)) Too tired to think last night, I guess. I solved it by trying to think of some similar equation I might have done in the past. I don't have a clue about what it means. But, as said, I only have to know how to type it in my calculator. phn by painful heel lock. |
#5 |
Doh!
Not long after I left home did it hit me. It calculates paralleled resistors. I knew that. You use it to set the load for MC carts. |
#6 | |
The formula full of reciprocals of reciprocals is good if you have three or more items connected in parallel. For just two it is usually easier to remember and calculate A*B/(A+B). I_F |
#7 |
The engineer in you speaking, eh?
And here I was all happy having solved it on my own. Not bad, I think, considering I have forgot, if not everything, 95 pct of what I learned in high school. I think and hope this is HS level. But then, I probably have forgotten 95 pct of everything I learned in school. Thinking about it, I don't know what I learned in school other than being quite and feeling shame if you didn't. Man, what a hellhole it was. |
#8 |
If phn's calculator has a reciprocal function key (say "1/X" or x^-1); then the reciprocals of reciprocals is less keystrokes than the reciprocal of the LCD (least common denominator, A*B) form for 2 resistors even if A and B are only 1 digit each. You would enter: A, rec key, +, B, rec key, equal key, rec key
Also the reciprocal of the reciprocal form allows you to do a problem like: I need two resistors in parallel to make 10K and I have a 22K resistor, what do I need? => 1/((1/10K)-(1/22K)), without breaking a sweat! The form A // B => A*B/(A+B), should never be taught; as it has no intuitive connection to conductance => 1/resistance which is at the heart of combining resistors in parallel and understanding how to calculate the answer in general. Just an observation and opinion, all correct answers are equivalent! VSR |
#9 | |
frugal-phile(tm)
1/x = 1/A + 1/B as per your formula... dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 | |
frugal-phile(tm)
A, 1/x, B. 1/x + 1/x dave
| math problem ?? | prorms | Solid State | 8 | 19th December 2006 08:48 PM |
| Check my math? | Jalex420 | Chip Amps | 18 | 3rd June 2006 08:58 AM |
| Son of Zen and math | bertjan | Pass Labs | 5 | 10th February 2006 02:51 AM |
| Can't do the math! | poorstudent | Full Range | 3 | 22nd November 2005 06:37 AM |
| Need some Math Help... | ctardi | The Lounge | 3 | 21st June 2005 05:11 PM |
| Page generated in 0.11270 seconds (79.44% PHP - 20.56% MySQL) with 10 queries |
