| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have a group of HIGH power leds that need about 24v to
run. I would like to turn them on slowley going from off to 500ma over a period of an hour. Any realy simple circuit ideas ? |
#2 |
Woody,
The 1 hour progressive turn-on time for your LED driver seems to make inexpensive analog solutions impractical. So, a 5V microP with a DAC output, driving a GND referenced opamp, driving a NPN or N mosfet current source would seem to be simple and cheap. A LM324 class opamp (cheap, rugged) has common-mode range down to GND so its reference input could be directly driven from the DAC out. The sense resistor on the Em (Source) to GND would be scaled for 500mA at max DAC output voltage. The LM324 could be powered from your LED bulk supply. The programming could be changed to accomodate various turn-on/off strategies, and unused inputs could be programmed for external sensors for additional contol options. You could use a large variety of cheap PIC processors, or Basic programmed derivatives, should you wish to avoid the obtuse and frustrating initialization for the bare PIC's. My favorite derivative is the PICAXE from the UK (Revolution?). A suitable microP would cost less than $10. One reseller in the USA is phanderson.com. He is a prof. at Towson State in MD and has written a lot of microP applications material on the web in support of his classes using microP's. If you DIY for the programming support hardware; you can get away for less than $10 (assuming you have a PC available). Manuals/Forum/PC Software free on the web from the UK. Just a thought! VSR |
#3 |
All u need is CD4541, CD4017,Cd4093,LM317 and few transistors.
Make an oscillator from CD4541 of 1 pulse in 7 minutes, connect a CD4017 and use the outputs to control LM317. For details see on the applications of LM317 on national site. Use 4093 to inhibit the counting. Edit: Use 4093 for power on reset also Gajanan Phadte |
#4 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
I suppose it could be increasing the life of the LEDs
Woody only knows Gajanan Phadte |
| Soft Start Necessary? | dtaylo3 | Class D | 2 | 26th December 2008 09:05 AM |
| B+ soft start | Gluca | Tubes / Valves | 2 | 3rd September 2007 01:04 PM |
| Need a soft start? | maxpou | Solid State | 19 | 18th April 2007 09:23 PM |
| Soft start & Soft Switch circuit: can anybody help? | m.parigi | Solid State | 95 | 22nd August 2005 03:32 PM |
| Page generated in 0.09340 seconds (76.02% PHP - 23.98% MySQL) with 10 queries |
