| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have several 0.9mm HSS drill bits that are worn out.
How can I re-sharpen them ? Is there any jig to hold them at the right angle and sharpen them against a small grinding wheel ? Any other short cut methods ? Thanks, Ashok.
AM |
#2 |
A ceramic cased EPROM or microprocessor case works about as well as a real ceramic sharpening stone for sharpening small drill bits and knife blades.
#3 |
Thanks. However I want to know at what angle the tip should be ground and how (angle ) should the drill bit be held.
Doesn't anyone on the forum do this ?
AM |
#4 | |
I like the EEPROM suggestion, mind...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#5 |
I just eyeball the angle when I use the EPROM sharpening stone. HSS bits in small sizes (like #70) go dull very quickly when drilling glass-epoxy boards, like maybe after a few dozen holes, so any improvement in sharpness helps.
I prefer to drill boards using 1/8" shank carbide bits; after buying a couple new for an appalling price (and breaking them), I was lucky enough to score a heap of them at a swap meet. There's several vendors selling assortments of them on eBay very cheaply, or your friendly local tool/hobby stores may have them. You must use a drill press since the bits are so brittle. |
#6 |
A normal drill has a angle of 118 degrees (factory made)
drills for aluminium do have an angle of 135 degrees, because aluminium is a softer material, 135 degrees cuts more controled. Machine drills do often have an angle of 90 degrees. I re-sharp my drills just bij hand. Most importand is to keep both sides te same. Depending the material you want to cut you can alter the angle. Just give it a try you lose nothing Unless you have shakey hands ![]() And all non machined sharpend drills will give you an unround hole so if that is importand for you, buy new ones. |
#7 |
After seeing a post on drilling circuitboards last week here I decided to build this
http://www.powerlabs.org/railgunprogress.htm What I couldn't find at Home Depot I borrowed from my wife's Honda Civic and a 1972 Zenith console television set. I set it up with a laser guide and am cranking out perfect holes with micro slugs and matching barrels/rails sized from .001 mm on up to 1.5 mm - as fast as I can hit the foot pedal. |
| Carbide Drill Bits for Sale or Trade | DSchmidt | Swap Meet | 0 | 22nd January 2006 10:26 PM |
| To drill or not to drill? (a VPI turntable) | m.parigi | Analogue Source | 5 | 6th January 2006 03:32 AM |
| Drill sharpening | Koy | Equipment & Tools | 6 | 1st October 2003 02:57 PM |
| where to get teeny tiny drill bits? | cowanrg | Parts | 20 | 2nd August 2003 07:54 PM |
| Where to buy PCB Drill bits in Hong Kong ? | audio_cf | Parts | 7 | 29th January 2003 01:53 PM |
| Page generated in 0.10552 seconds (73.83% PHP - 26.17% MySQL) with 10 queries |
