| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hello all,
I am not sure that this trhead is in the proper forum ... I am looking for all your knowledge on how to twist wires together without by hand in order to make long run of proper twisted wire for audio cables. I have found this http://www.aircraftspruce.com/menus/...wiretools.html and this http://www.amazon.com/Bon-Tool-Co-Wi.../dp/B00067T9OA but I do not know how this work. I have found that too http://www.twistechnology.com/?go=33...e70084a751273a but this is out of my budget ! Give to this forum your ideas, diy tools or machines, tips and so on. I think this will help many of cable builders. Thank you
Audiophile and audio products designer |
#2 |
Use a variable speed drill. Either a helper or a vise on the other end. Keep things taut, and after twisting, release the tension slowly.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
#4 | |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
I don't quite agree with the drill technique. I don't know if it's bad, but it does put stress on the wires. If you twist two individual wires loosely by hand, they will stay twisted. No force is needed.
Of course, twisting long wires this way isn't easy. |
#6 |
i have a thin, 50mm diameter circle of lexan, it has holes spaced equally around the centre of various diameters,and each one is slightly flared.
just thread the wires through, vice one end and rotate to twist. pretty much stress free and easier to get accurate twist per distance unit than with a drill.
hoping to pick up some things. |
#7 |
Shorter lengths, use the advise as per any above ( or your own choise: http://www.aircraftspruce.com/menus/...wiretools.html ) ... longer lengths, 10+ feet, best consult with a rope maker or learn about braiding.
Over compression is a problem with modern CD recordings |
#8 | |
#9 |
" ... Silver wire will break using this method, though. ..." ... shorter lengths under 6 feet = no problem-o.
#10 |
I too use a power drill, but I leave the other ends of the wires loose and separated. As the drill spins the two wires together on one end, I let the other ends of the wires spin and rotate. This allows the wires to twist while being spun and gives a much tighter winding that will maintain its integrity when moved and handled. This works best with stranded wire with reasonably flexible insulation. I’ve never used silver wire, so I can’t comment on its breakage.
I’ve used this method for twisting copper varieties of wires in lengths from 6-inches to 30-feet with excellent results and zero failures.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so." |
| overhang adjustment vs. twisting in slots | ilewis33 | Analogue Source | 2 | 17th March 2009 01:55 PM |
| Twisting and Braiding Cables | ralph-bway | Multi-Way | 19 | 29th December 2008 09:09 PM |
| Twisting Wires....which ones ? | redrabbit | Power Supplies | 2 | 24th February 2008 06:47 PM |
| Twisting transformer wires? | Dominick22 | Chip Amps | 29 | 1st June 2006 10:34 PM |
| Conductors (I.C.'s, RCAs, internal wires, speaker wires) | bigphil | Parts | 1 | 25th November 2005 06:47 PM |
| Page generated in 0.13601 seconds (72.93% PHP - 27.07% MySQL) with 11 queries |
