| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
I've been using Firefox for the past year, I really like it.
Jeff |
#12 |
Thanks guys.
The problems started when the PC refused to start a couple of days ago. Nothing. I first thought the motherboard had fried. In fact, I was pretty sure something major had happened. But before taking it to the dealer I checked all connections and cleaned it. I don't want to have the dealer tell me there's nothing wrong with it. Whatever was wrong was now fixed. Later the PC started to crash. I used Win 2000 before going XP. The only differences I can see between the two are that it's easier to set up a network with XP (everything is PnP) and that XP is a lot more stable. It had never crashed before. I use the "Classic" Windows look, so there's really no difference in my case. I do have Ad-Aware and Spybot. But I have no active anti virus program. And I have ZoneAlarm, which is one program I couldn't live without. Without it I wouldn't know what goes on in my PC. I will check the links you have posted. An active anti virus program wouldn't hurt. I used to have Norton. Unlike others here I never had any problem with it. It does bog down the PC slightly. I would be more concerned if it didn't. The thing is, I don't visit any potentially harmful sites, type Astalavista. I don't use any P2P. I don't download stuff. I now use msconfig, a program I always used in the past but haven't bothered with the last couple of years. |
#13 |
Like you, I have used both Norton's and Zone Alarm. Both Kerio and Nod32 are better options because they not only do a better job overall, they require significantly fewer of the computer's resources. They are definitely worth a look.
#14 |
Its never a bad idea to have several virus scanners running. Unfortunately some don't coexist very well.
AVG and Antivir (both free) are permanently installed on my system without problems. As malware removal, I use hitmanpro, a nifty batch program that runs a bunch of free anti-spyware tools. A real pest to get rid of are rootkits. One of the best detection tools is RootkitRevealer. www.free.grisoft.com http://www.free-av.com/ www.hitmanpro.nl. http://www.microsoft.com/technet/sys...tRevealer.mspx /Hugo |
#15 |
Hi Guys
I had some close calls over the years and recently changed over from N/S to Panda. No complaints, everything a bit faster. Oh. well - if I HAVE to have a niggle - the pop-up pane informing all is OK IS a bit big... @ The inimitable, one and only mosin. Regards from the southern tip of l'Afrique du Sud! bulgin PS Hell, I love them bakelite plugs and sockets |
#16 |
My desktop is dead again. It lights up and you hear the usual start up noises/relay-type clicks. But nothing happens. The "hard drive lamp" lights up (it doesn't blink) and then goes out after maybe 15 seconds. No connection with the monitor. I tried another hdd I have laying around. It's defect, but does sort of work. So it's not hdd related. I suspect it's the PSU, but can't say. I got rather weird measurements from the 5/12V hdd connector (I'm sure it has a name): 12 some volts and 7-something. That may not mean anything. And I did the measuring quite hastily.
#17 |
Bad PSU, bad and/or dusty CPU and video card blowers and bad MoBo (capacitors) is what I would check first.
/Hugo |
#18 |
The PC's up and running again!
I couldn't say, but suspect it's the PSU. I hope it is, anyway. It makes this annoying high-pitch whining whenever you do something. Have wanted to replace it with one of those silent PSUs for a long time. But I hate fixing with the PC. Now I have the excuse to do it. |
#19 | |
/Hugo |
| Decca DMI-73 and EL-84 weirdness | uliami | Tubes / Valves | 9 | 4th May 2011 01:56 AM |
| Optimum WinXP partition size. Weird situation | SunRa | Everything Else | 10 | 22nd January 2009 01:48 PM |
| WinXP question for gurus. This is a tough one! | mpmarino | The Lounge | 0 | 5th March 2006 04:15 AM |
| transformer weirdness | taj | Parts | 3 | 20th May 2005 03:28 AM |
| Software speaker simulation weirdness | jteef | Multi-Way | 6 | 12th January 2002 09:59 AM |
| Page generated in 0.20970 seconds (43.82% PHP - 56.18% MySQL) with 10 queries |
