Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
CD player --> active speakers volume control
Old 5th March 2007, 04:28 PM   #1
badger12345 is offline badger12345  United Kingdom
Default CD player --> active speakers volume control
Hi there folks. Just came across this forum, and it looks like a great place to pick up some tips on home audio. I like to make my own music, so I've got a pair of Tannoy reveal active monitors for mixing. Last week someone gave me an old CD player (Technics 490) as I didn't have a decent one. Unfortunately, the phono output level is way too high for my active speakers, so I'm trying to build my own simple volume control. Could anyone suggest what kind of potentiometer I should look at for this task? Any help would be very gratefully received.
mike
Old 5th March 2007, 04:45 PM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Hi Mike and welcome to diyAudio.
There are several options, depending on how complex you want to get. Have a search on Passive Pre(amps) for some opinions. As for a pot, personally speaking, Alps Blue Velvet is a good start, or if you just have a problem with one channel, then you could sort your problem with a couple of resistors soldered inside your connectors. Search for attenuator pad.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 5th March 2007, 04:45 PM   #3
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Just try a 10k log pot and see how you get on.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 5th March 2007, 07:05 PM   #4
Terrific stuff chaps, thanks very much
I'd pretty much decided that something along the lines of a blue velvet dual channel pot would work nicely. Simple enough for me. Does the rating of the pot affect the maximum level of attenuation? I mean, is it critical that I choose, say, a 10k pot over a 50k?
It's great fun this DIY audio. Might just have to get into it..!
Thanks again.
mike
Old 5th March 2007, 07:43 PM   #5
Did it Himself
Yes the pot value is quite critical. If it's too low it will load the CD player too much, if it's too high the speaker will load the pot too much and skew the response vs rotation curve.
TBH a passive volume like this is not ideal but it will work.
Old 6th March 2007, 10:01 AM   #6
phase_accurate is offline phase_accurate
IMO it doesn't matter that much when the response vs rotation curve is spoiled. I always set the loudness levels acoording to my ears and not to my eyes. I therefore even use a linear APLS in my "passive preamp".
Linear pots have the advantage that they have better channel similarity (don't know better words for that) than log types.
But the pot value definitely affects the upper cutoff-frequency by forming an RC lowpass together with the capacity of the cable connected to it.
My pot is a 10k type giving a worst-case cutoff-frequency of 200 kHz together with the low capacitance cable that I use.
Charles
Old 7th March 2007, 11:14 AM   #7
Thanks for that.
I checked the specs on my speakers and it turns out the inputs have a 37k input impedance. I 'think' therefore that a pot of either 10k or 50k would probably be ok. Does this sound about right?
Thanks again.
CD player --> active speakers volume controlHide this!Advertise here!
DVD/CD player with Balanced XLR output and volume control Freddie Everything Else 9 2nd March 2015 03:58 PM
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
Inexpensive multichannel volume control for active loudspeakers Dan_E10 Multi-Way 3 14th October 2008 01:19 AM
CD player with volume control? MEXXX Digital Source 6 22nd December 2004 02:25 AM
DVD Player & Volume Control bimbla Everything Else 6 25th December 2002 12:14 PM
