Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Stereo multiplexer, general questions
Old 3rd March 2007, 08:13 PM   #1
2litre is offline 2litre  United States
Default Stereo multiplexer, general questions
Just two general questions on this.
If I have an old AM/FM tube tuner from a console radio, that isn't known to be a stereo unit originally, and I purchase a tube multiplexer, can I "just plug and play" stereo?
And does the brand matter, say a motorola multiplexer and a Magnavox tuner?
Thanks,
Jim
Old 3rd March 2007, 11:13 PM   #2
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
You need an IF output from the tuner to the demultiplexer. The old Scott tuners, some cheesy Eicos, Heathkits, and any others that came out around the time that stereo broadcast was introduced usually have outputs to drive demultiplexers.
Yes, the brand probably matters because there is no "standard" for the IF output level. You could probably modify just about any demultiplexer to work with any tuner with an IF output, assuming the IF frequencies are the same.
This all begs the question of why you would want to go to all this trouble, unless you're just into listening to old equipment. Modern equipment performs so much better and will work so much more reliably...
I_F
Old 4th March 2007, 12:03 AM   #3
Thanks for the input,
Mainly curious because I have some old tube gear pulled from some consoles I purchased back before e-Bay sent tube gear thru the roof. I picked them up for the drivers mainly and just set the electronics aside.
The Magnavox tuner I'm refering to has an 'FM out' which I figured went to a multiplexer and was curious about brand interchangeability because of a Motorola unit I saw on e-Bay yesterday.
R/
Jim
Stereo multiplexer, general questionsHide this!Advertise here!
ER Audio ESL III Kit, and ESL questions in general wixy Planars & Exotics 27 30th July 2014 12:14 AM
general chip questions Ropie Chip Amps 2 11th July 2004 10:05 AM
2 general sub questions, please Misa A. Multi-Way 3 22nd March 2004 06:54 AM
SOZ amp general questions MEGA_amp Pass Labs 4 27th October 2003 03:53 PM
