| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I found this project on the web "Practical voltage converter":
http://web.telia.com/~u85920178/power/vconv_01.htm I built it and substituted TIP33C and TIP42C for BC547/557. Also I reversed polarity on the electrotyic caps and diodes because the goal was negative 12 volts. Attached is the pcb with component overlay. With 12 volts attached I get no output. ![]() Q1,Q2,Q3 are TIP33C THe PNP is TIP42C
none |
#2 |
You need to figure out whether it is oscillating. You'll need an oscilloscope, or maybe you can try to measure its frequency a frequency counter or a DVM that has a frequency measuring capability.
Have you emailed the author of the circuit? |
#3 | |
Magneto the Gravity Man
If you read the article carefully, the original circuit gives either +24v or -12v depending on the positioning of the link. There is no need to change polarity on the caps or diodes. Andy EDIT You have also made errors on the pcb. The emitters of the output pair are not connected to anything. The cap goes to the bases of the output pair not the collector. The diodes are wrong. redo the board !!!!!!!!!!!!! Cheers Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#4 |
Speaking of careful reading:
The links LK(x) refer to the links on the PCB component overlay. If the LK1 RED wire is removed and the BLUE wire is fitted, then the circuit will provide +12v, +24v, +36v and +48v. The first option (+12v) may not seem very usefull since this is the same as the input voltage, but if all electrolytic caps and diodes are reversed, then the board will provide -12v, -24v, -36v and -48v. The author also marks the links and outputs in RED and BLUE...if reversing the diodes and caps is not needed then the article is unclear to say the least.. You are correct about the output transistors ...got confused by the parts overlay..
none |
| Switching 230 Volt Transformer to 120 Volt | OMNIFEX | Parts | 10 | 6th April 2008 04:34 PM |
| I Need 24 To 220 Volt Converter | EQUINOXE 54 | Power Supplies | 7 | 23rd January 2006 05:44 PM |
| 24 to 220 volt 1200 watt converter | EQUINOXE 54 | Power Supplies | 0 | 19th January 2006 09:56 AM |
| Volt in a TL | BlackCatSound | Multi-Way | 24 | 1st November 2004 07:29 AM |
| 9 volt DC to 48V DC | Ricren | Parts | 12 | 19th October 2004 08:02 PM |
| Page generated in 0.07416 seconds (76.13% PHP - 23.87% MySQL) with 11 queries |
