| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have searched for a thread on Cat 5 as a speaker cable. Nothing came up. Is there any information anywhere on the forum as to how the cable shoudl be made up ?
I seem to remember seing a twisted cable which I believe was Cat 5. What I need to know is :- 1. What is the best Cat 5 cable to use i.e what gauge. 2. How many strands should be twisted together for each conductor (if twisting is what you do) 3. Any other tips on making a good CHEAP Cat 5 cable. Thanks |
#2 |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
Making CAT5 speaker cables is a pain in the you know what. IMHO it's not worth the sore fingers, but if you really want to make them you could do something like the pic below.
There are 9 twisted pairs total. 3 twisted pairs braided + 3 braids braided = 1 speaker cable of around 15 AWG. If you use all the solid colors for one connection and all the striped for the other; you will retain the benefits of the twisted pairs. In theory the twisted pairs have lower inductance, but I'm not sure if that is negated in any way by braiding multiple pairs together. Another benefit to the twisted pairs would be lower radiated noise from the cables. Possibly a good thing when used with class-d amps. The three braids in the pic are actually for interconnects I'm making. I braided three of them together so I could take the pic. I haven't tried them as speaker cables. I guess the easiest way to make cables would be to take 10-20 twisted pairs and just run them through some sleeving. Simple, quick, and it would look good. http://www.partsexpress.com/pe/showd...number=082-380
"If you don't like funerals don't kick sand in ninja's face." |
#4 |
Welcome to the league.
Oyvind´s Hifi Page I´ve read this and many others pages in the web. At the end I made mine with four braided whole (not stripped) Cat6, same as TNT Audio. Cheap. Cheers.
Jose Carlos |
#5 |
Cat5 works fine. But there is no single one size fits all solution here -which will be best depends on your system.
#6 |
CAT5 speaker cable works by paralleling a lot of twisted pairs and reducing series inductance at the price of higher parallel capacitance. I'm not a huge fan because of the PITA (pain in the tuchus) factor.
I prefer using four parallel runs of mini RG-8, with all the cores tied together and all the shields together. You end up with a series L of about 0.02 uH/foot at about 10 gauge equivalent. It's not quite the beefy 6 gauge equivalent of quad full-size RG-8, but it's a damn sight more tractable. I tried the Risch crossfeed, but I liked the straight parallel configuration better. |
#7 |
This is really easy:
http://mark.rehorst.com/Audio_System/speaker_cable.png No twisting to do. Just crimp on a couple PCB/ribbon connectors, insert a couple double sided PCB pieces, solder on some short leads and the connector of your choice and you're done. Lays flat under carpet! Verly low inductance and resistance, high capacitance. I_F |
#8 |
#9 |
diyAudio Moderator Emeritus
Most important is that you use the solid core versions.
#10 |
Dumb question-what's the DC withstanding voltage on CAT-5? Is it part of the standard or is it different from manufacturer to manufacturer?
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
| cheap cat5e cable for speaker cable | fishline | Full Range | 6 | 19th May 2009 08:42 PM |
| problems with speaker cable as power cable | pjpoes | Parts | 11 | 14th January 2007 09:24 PM |
| 25 pair cat 5 cable for speaker cable? | mpmarino | Parts | 19 | 3rd March 2006 05:46 PM |
| Speaker Cable | Bgt | Multi-Way | 0 | 21st July 2005 05:08 PM |
| electrical cable for DIY speaker cable? | leadbelly | Multi-Way | 7 | 13th January 2004 11:43 AM |
| Page generated in 0.09817 seconds (87.27% PHP - 12.73% MySQL) with 10 queries |
