Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Dual transformer polarity/wiring
Old 2nd March 2007, 12:07 PM   #11
soongsc is offline soongsc  Taiwan
soongsc's Avatar
I think connecting two transformers together is not a good idea since the phase relationship between the primary and secondary might not be exactly the same. I would connect these through two rectifiers first and then pull the DC together.
Hear the real thing!
Old 2nd March 2007, 12:20 PM   #12
R.I.P.
Hi Soon,
I suspect even your third alternative will similarly make no difference to the sound output, other than the loss of that extra 1.4volts will have on earlier clipping.
regards Andrew T.
Old 3rd March 2007, 12:05 AM   #13
soongsc's Avatar
Originally posted by AndrewT
Hi Soon,
I'm not sure where that 1.4Volts comes from. But I once used a transformer that had two 25V outputs rather than centertapped, connecting two in series created a little 60Hz little signal (little worm between flats that occur at around 60Hz) in the ground loop that could never be removed. Perhaps there is a different explanation?
Old 3rd March 2007, 07:05 AM   #14
R.I.P.
two rectifiers loses 2.8v whereas one rectifier loses 1.4v. I think you saw that.
Bad grounding caused the buzz, not the change to/from single rectifier.
regards Andrew T.
Old 3rd March 2007, 08:09 AM   #15
soongsc's Avatar
Well, looking at the shape of the signal did not convince me it was a grounding problem, and switching from a two secondary to a center-tapped one took care of the problem in my case. So I would not connect two transformers together directly.
Old 20th March 2007, 03:19 PM   #16
deduikertjes is offline deduikertjes  Netherlands
deduikertjes's Avatar
For me this is definitely the better option. I tried both.
In my system neg. and pos. supply lines are not equally loaded en by this both transformers are not equally loaded, but connected to each other. This resulted in some mechanical hum in the transfromers. Going to two rectifiers cured that. This also cured the difference in output voltage for the pos. and neg. half of my supply. They are now within 0.1 V (was 1.8).
The resulting voltage under load was actually a little higher with the two rectifier option, so it's not sure if you'll lose to extra 1.4 Volts mentioned.
By the way on TNT audio the two rectifier option is preferred for 1 transformer with centretap as well. At least it takes some load of the rectifier.
greetings, MArco
Dual transformer polarity/wiringHide this!Advertise here!
Transformer Polarity WRyan Tubes / Valves 5 8th February 2009 12:51 PM
Help with phase/polarity of transformer jakebrown5 Power Supplies 21 27th August 2007 01:38 AM
Does (primary) transformer AC polarity matter...? ptwining Class D 14 28th October 2006 12:19 PM
Question about Dual Polarity Power Supp. (Ashamed to ask) TaaJ Chip Amps 11 28th August 2004 09:27 PM
