Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th February 2007, 02:11 AM   #1
wildswan's Avatar
Unhappy Why is this opamp saturating?
Hi everyone,
I've put together a wein bridge oscillator, or should be.
The problem is that the opamp keeps saturating at the positive rail.
I've removed the gain control part, from the circuit (by removing the BC182) so I'm pretty sure that it's the oscillator itself.
I can't figure out what would cause this....opamp circuits aren't my strongest point
Please help, this is driving me nuts!!
Thanks in advance
Old 13th February 2007, 02:48 AM   #2
I_Forgot's Avatar
Could it be because both rails are +12V as shown on the diagram?
I_F
Old 13th February 2007, 03:31 AM   #3
wildswan's Avatar
LOL no, that's just some messy component placement! The real circuit uses proper power rails!
Old 14th February 2007, 07:10 PM   #4
wildswan's Avatar
I traced the circuit, everything is wired as it is supposed to be
I replaced the opamp (with a TL074) in case I damaged it while soldering, but no dice.
Going to rebuild. AGAIN!
Old 14th February 2007, 08:30 PM   #5
wildswan's Avatar
No, I'm just stupid
Had resistor in parallel with feedback cap, where it should have been in series. Hence +ve DC feedback.....
Old 15th February 2007, 05:24 PM   #6
AndrewT is online now AndrewT  Scotland
buy yourself a plug board to test out ideas and prototypes.
Avoids all the soldering and PCB difficulties and so easy to try different values of components.
Only £2 or £3 for a simple one.
regards Andrew T.
help me with this opamp pre-amp fastvideo Solid State 9 20th July 2008 10:55 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Opamp Vcc computeruser Solid State 5 13th October 2005 03:27 AM
Which OPAMP kestrel200 Solid State 14 23rd August 2005 09:20 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
Page generated in 0.08723 seconds (72.29% PHP - 27.71% MySQL) with 11 queries
