toggle circuit doesn't work toggle circuit doesn't work - diyAudio
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 10th February 2007, 05:54 PM   #1
turner is offline turner  Germany
Lightbulb toggle circuit doesn't work
hi folks,
i build a toggle circuit to switch on my diy amp with a pushbutton (not a switch!). the toggle circuit is based on a 4027 mos, the circuit is shown below:
the truth table of the 4027 is the following:
when turned on, Q is high and the "off led" is on - fine and ok.
when i push the button, Q/ is high and the "on led" gets on and the relais closes - fine and ok, too.
this state should last until i push the button again, but as soon as i put my fingers off the button, Q/ gets low, Q high and i can see the "off led" laughing at me.
so anybody an idea, whats wrong with the circuit? i changed already the 10uF cap at clk and put a smaller one in - 0,22uF - but without any result, all the same.
thanks for help
so long
turner
Old 11th February 2007, 07:39 PM   #2
Perry Babin is offline Perry Babin  United States
Have you tried adding a capacitor across B+ and ground?
Have you tried grounding the reset pin?
This is a circuit I built for someone. If you have a CD4013B, you may want to try it. You have virtually all of the other parts you'll need.
http://www.bcae1.com/opamptemp/flipflop01.swf
Old 11th February 2007, 09:06 PM   #3
what do you mean with B+? reset is low, this shouldn't be the problem i guess ...
so long
Turner
Old 11th February 2007, 09:15 PM   #4
B+ = 12v
I was concerned that the reset line may be picking up some noise from the B+ line. This could cause it to reset.
Does the circuit work properly if you remove the relay? Replace the relay with a 1k ohm resistor to see if the relay is causing the problem.
Are you 100% sure that the IC is in good working order?
Old 11th February 2007, 09:34 PM   #5
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
You are assuming that the switch behaves perfectly, opening and closing without any bounce. That's the problem with this type of simple circuit.
When you open or close a switch the contacts bounce for a few ms. That is plenty of time for the circuit to switch.
Have a look at some of the circuits here:
http://ourworld.compuserve.com/homep...wden/page9.htm
The 555 timer based circuits should work more reliably...
I_F
Old 14th February 2007, 11:30 PM   #6
cpemma is offline cpemma  United Kingdom
Some tried & tested bounce-free circuits.
The Winfield Hill one is cheap and simple (and with that provenance...)
toggle circuit doesn't workHide this!Advertise here!
My scope doesn't work - need help! Giaime Equipment & Tools 17 23rd September 2011 06:47 AM
Help-Car deck Doesn't work jatminder Car Audio 2 10th July 2006 08:13 AM
Right Channel on my amp doesn't work?? nicku1302 Solid State 2 29th November 2005 03:58 PM
adcom gfa 545 II doesn't work Mattyo5 Solid State 1 14th February 2004 12:39 AM
Copyright ©1999-2017 diyAudio
