| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
OK So I know about the connect the ground wire to the green wire to make a ATX power supply work when not connected to a Mobo. But MY next question is do I need a load to make it automatically stay on and " act like a AT power supply"?????? I have googled some and it seems I need to put a 10ohm/10v resistor or 2, 5v 5ohm resisters in series across a set of red and black wires. IM ok with all that But just was curious when I just jumper the green and black wires and plug in a sacrificial computer fan into the red and black wires I get a momentary attempt at the fan trying to run. Was this due to the fact that a single pc fan isnt a big enough load? and thus no continuous power? Thanks again.
#2 |
#3 | |
Magneto the Gravity Man
Hi. Yes, you do need a load. About 0.5A, usually on the +12v line, will keep it going. ( yellow / black ) [I used an old 3.5" hard drive for testing PSUs] The connection between the 'Power on' and ground is only momentary. Using an old AT supply is much easier and, with 12 years as owner of a computer business, they are more reliable!! Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
| Power load, dummy load (pic) | luka | Power Supplies | 43 | 9th February 2012 02:50 PM |
| if a power supply load is pulling 3A, does it means... | jarthel | Parts | 8 | 24th April 2007 12:58 PM |
| Power supply FET's overheats in seconds - no load, why? | valterdaw | Car Audio | 12 | 2nd July 2006 01:46 PM |
| Power supply load capacity | Dr.Frankenstein | Tubes / Valves | 2 | 19th September 2004 11:24 AM |
| No Load Voltage on Zen V4 Power Supply | vsr123 | Pass Labs | 13 | 5th May 2003 04:10 PM |
| Page generated in 0.07309 seconds (74.42% PHP - 25.58% MySQL) with 10 queries |
