Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Two Amps Powering One Driver
Old 3rd February 2007, 05:26 AM   #1
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Default Two Amps Powering One Driver
Hello, I'd just like to ask a couple of elementary questions if I may.
An 8 ohm speaker rated at 500 watts is hooked up to two amps in parallel. In both cases, the amps are delivering the same program material.
A) In one case, amp A is 200 watts, the second amp is 20 watts. What happens when they both deliver full power? I mean to both amps and speaker.
B) Both amps are rated 100 watts. What happens to them and the speaker?
I'm interested if both amps are tube amps instead of solid state, would that change anything?
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 3rd February 2007, 02:11 PM   #2
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
A)
B) Assuming they are identical amplifiers that can even be paralleled, you won't gain anything. You will still have the same voltage swing on the outputs, but twice the current capability.
Old 3rd February 2007, 02:16 PM   #3
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I can only agree with theAnonymous1 .....
A) The 20W amp will most likely get fried and proberly cause the 100W amp to get fried too
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 3rd February 2007, 10:06 PM   #4
XEAGLEKEEPER is offline XEAGLEKEEPER  United States
XEAGLEKEEPER's Avatar
Have fire extinguisher ready at hand
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 3rd February 2007, 10:20 PM   #5
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
Two Amps Powering One Driver Send a message via MSN to AKN
Also..
If we are talking about paralleling two amps they must be identical, very much so infact.
Imagine the amps has slightly different phase response, usually common in the ends of audioband. Large currents will then travel betwen amps and......
/ Anders
Old 3rd February 2007, 10:27 PM   #6
anatech is offline anatech  Canada
anatech's Avatar
Hi kelticwizard,
The 20 W amplifier bocomes another load, a low resistance one. The excess voltage will dump into the lower supplies through the outputs or drivers (breaking down in reverse) or the flyback diodes.
If the gains are identical, there will be some form of current sharing. If even so much as the phase shifts between them, one becomes an unhappy load. Excessive currents will flow.
Yes, if the amp is made to do this and the gains are the same, you change taps and the relatively high output resistance will current share. A tube amp with very high damping factor may have issues with this, or if the channels do not have the same gain (ie a fault with one side).
-Chris
Old 3rd February 2007, 10:40 PM   #7
Burnedfingers is offline Burnedfingers  United States
I sincerely doubt that this would work with any type of amplifier.
What would be the advantage of even trying it?
Old 3rd February 2007, 10:47 PM   #8
anatech's Avatar
Hi Joe,
Many tube amps were set up to do that. Connect both together on the 16 R tap and connect an 8R speaker there also.
More power!
-Chris
Old 3rd February 2007, 11:05 PM   #9
Chris,
Wouldn't it be simpler just to use a higher powered amplifier? When one looks at the possible problems involved it just isn't logical to do it. What happens when/if one amplifiers lets out some magic smoke? Damage will result and this damage would be more extensive than it would be with just one amplifier in the mess. Well, there is driver damage also that more than likely will result. Call me cautious but I will opt for a larger amplifier every time but then again thats just me.
Old 3rd February 2007, 11:10 PM   #10
anatech's Avatar
Hi Joe,
Absolutely!
There was a time when high powered amps were terribly expensive and rare. The solution was to use a couple stereo units as mono units. I'm talking about the 50's and possibly early 60's. Not now.
-Chris
Two Amps Powering One DriverHide this!Advertise here!
New National driver chip for BIG amps Marshallf3 Solid State 2 31st July 2007 12:06 AM
Powering three Chalize amps - Invisus ark Class D 4 30th July 2007 09:36 PM
Powering Up Old Tube Amps/Receivers DreadPirate Tubes / Valves 3 21st January 2007 03:23 AM
Powering car amps with power supplies msharpe Car Audio 17 21st May 2006 08:35 PM
Copyright ©1999-2017 diyAudio
