Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 28th January 2007, 10:18 PM   #1
Default Designing PCB's at GHz
I got bored and went googling when I found some pictures of PCBs designed for GHz signals.
I knew before I saw the pictures roughly the amount of voodoo design effort it takes to produce these, but some of the boards looked literally as if they'd been pulled from a UFO. The traces had crop circle and aztec writing style elements to them. 'Random' traces start and stop and seem to connect to nothing, or curve around and come to a dead end, or fan out in a cone shape with nothing on them.
Does anyone know any good books that cover what the superstar jive powered funk is going on with these things? They're just unbelievable.
Old 28th January 2007, 10:33 PM   #2
pinkmouse's Avatar
I was recommended this one, but I didn't have the money to purchase at the time.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 28th January 2007, 10:47 PM   #3
I_Forgot's Avatar
All those shapes are about controlling impedances. If you put a short at the end of a 1/4 wavelength stub, the other end of the stub looks like infinite Z, for example.
Those boards are usually some expensive materials- ordinary G7 isn't manufactured under tight enough tolerances to get controlled impedance lines. Teflon and other high dielectric constant materials are used to keep tolerances tight and line widths narrow, and to minimize thickness of the substrate (this minimizes ground inductance).
I have a couple books in boxes somewhere from back when I used to design RFICs... let me see if I can find them and get the titles..
I_F
Old 28th January 2007, 10:52 PM   #4
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Lots of good reading on the web. Search for microwave or high frequency amplifier design.
http://web.syr.edu/~nkkunder/Nisha%20Projects/LNA.pdf
http://scholar.lib.vt.edu/theses/ava...cted/chap3.PDF
http://home.sandiego.edu/~ekim/e194rfs01/rfamp.pdf
Brian
Need help designing HPF add-on shaaregeulah Solid State 0 2nd May 2008 05:35 PM
Help designing a new set-up. djames03 Car Audio 4 12th May 2006 03:32 PM
Help please, designing a TL sub ShinOBIWAN Subwoofers 12 1st July 2004 04:14 PM
Designing for guys who like designing Sch3mat1c Tubes / Valves 14 31st August 2003 11:46 AM
This is the DAC which I`m designing purer Digital Source 12 26th July 2003 01:56 AM
Page generated in 0.08659 seconds (73.72% PHP - 26.28% MySQL) with 10 queries
