Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th January 2007, 11:12 AM   #31
kvholio is online now kvholio  Netherlands
kvholio's Avatar
Default Re: Re: I am joining the party!
Originally posted by BWRX
You have to end the polygon exactly where you started.
Eagle can do this for you.When drawing a polygon, double-click at the last point of the polygon you want to draw.
Eagle will automatically connect that point to your starting-point.
klaas
Old 29th January 2007, 06:13 PM   #32
sek is offline sek  Germany
sek's Avatar
Regarding the "Windows" - Paradigm: Eagle is Unix software, ported to Linux, Windows and Mac OS.
Cheers.
Old 29th January 2007, 06:29 PM   #33
Cheers.
Then I apologise, but for non Unix users (although I did "grep" around in past times ;-) it does start off being counter-intuitive.
I guess that means that "intuative" is what one is used to.
Old 29th January 2007, 07:29 PM   #34
sek's Avatar
Exactly, because applying tools to selected objects via the contextual menu is neither a Windows (or Microsoft) invention, not is it standard.
The usual - and actually more intuitive - way in professional tools (be it audio, video, graphics, design, etc.) is: first grab a tool, then use it on an object. Just like in real life...
OTOH, Eagle doesn't implement contextual menus at all, though. Why the manufacturer Cadsoft still does that is beyond me...
S.
Old 29th January 2007, 09:25 PM   #35
Default I think I have hijacked Sy's thread !
But while I have your attention .....
1) I am used to using a 0.1" dot grid. When I display it I still cannot place components so that a pad sits on a grid point. Some do, some don't and I cannot see the logic.
2) I can't see how to create a board outline. Obviously I can draw a line around the board, but how to get this on all layers? What about registration marks?
Now I see the Unix port and understand - most of the help refers to CLI. Pity as the basic engine is very good.
Old 29th January 2007, 09:30 PM   #36
lgreen is offline lgreen  United States
lgreen's Avatar
Default Re: I think I have hijacked Sy's thread !
A board outline is done with the 'dimension' layer as far as I recall. Select this layer and draw a trace around the board. It will show on all layers unless you disable viewing this layer.
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Old 29th January 2007, 09:56 PM   #37
aparatusonitus's Avatar
The same thing drives me nuts for a day...than I figure it out: if a component in question was place in different grid (like 0.0125"), and you copy it, and you decide to change a grid to 0.1", chances are (8:1) that the new component will be placed in incorrect grid. Switch the grid again to 0.0125", move the component a bit until it fix to 0,1" grid.
Non é mai abbastanza...
Old 29th January 2007, 11:42 PM   #38
sek's Avatar
Both questions have been answered (thanks ).
To add a bit: The grid is also imposed in the component library. If you happen to place a component into a grid that isn't anything like a multiple of the component grid, then the component center will match the grid and the component pins/pads won't! Changing grid after having placed components does also only work with "compatible" (e.g. multiple) grid values (smallest common denominator of any number of grid values in question).
Also, board outlines really only belong into the dimension layer, while registration marks can be placed onto each copper layer, for example. The Eagle distribution contains a couple of "scripts" to accomplish exactly this for you, namely by clicking "File" -> "Run Script" (or clicking the script tool button) and choosing, e.g., "euro.scr". This example script shows you how it can be done. I wrote my own scripts for various board size and registration mark types. You can also draw your favourite dimension outline and layer registrations into an empty board file and "Export..." it into a script file.
Sebastian.
Eagle / .lbr tobias_svensk Parts 0 25th June 2004 05:11 AM
Eagle for Mac OS X JohnG Parts 6 8th May 2004 09:52 AM
eagle nickgreek Everything Else 0 6th November 2003 12:24 PM
Eagle in 3D nickgreek Everything Else 2 4th November 2003 11:21 AM
Need help with Eagle cad Shaun Perez Everything Else 1 21st August 2003 07:35 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 18.18%)
Copyright ©1999-2013 diyAudio
