Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Acoustics - would this work?
Old 18th January 2007, 11:31 AM   #1
echosystm is offline echosystm  Australia
Default Acoustics - would this work?
Well, my accoustics are terrible and theres nothing I can do about it due to my living arrangement. OR IS THERE?
The plan is to build a room inside a room which I can take apart and transport to a new house if necessary. A number of pine frames will be built, filled with rockwooll and covered with some material. These panels will then be bolted together to form the room. The floor of the booth will be laid upon neoprene pads to separate it from the room entirely.
Sound PROOFING is not really an issue. I'm not worried about sound getting out, and there is not much sound to get back in - only that which is reflected back from the main room. The whole idea of this project would just be to achieve decent acoustics. For this reason, I would leave the faces of the panels open.
Ventilation will be covered by an external aircon with baffled ducts. So theres nothing to worry about in that regard.
Now, is this a stupid and totally impossible idea? Or is it within the realm of possibility? The room would be roughly 2 x 2.56 x 3.08m (Height x Width x Length).
Old 18th January 2007, 11:37 AM   #2
Burnedfingers is offline Burnedfingers  United States
Try pre-made accoustical panels. The results will be better and you won't end up with a cluster ****.
Old 18th January 2007, 11:38 AM   #3
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
What is the exact problem? If it's lumpy bass then your proposal won't help much. You will gain a pretty dead sounding room in the mid and upwards frequencies.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 18th January 2007, 11:41 AM   #4
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Before you spend lots of money, buy the Master Handbook of Acoustics, by F Alton Everest. It will help you find the room problems and solve them appropriately, and possibly cheaper and less disruptively.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 19th January 2007, 03:04 AM   #5
Sorry, I haven't really explained the situation well enough.
I can't treat any room in the house. It's not going to happen, even if the panels are freestanding. Despite much debate with the parents, they won't have any of it. Tough love huh?
They have said, however, that I can do whatever I want out in the garage (a huge corrugated iron shed). I can't simply hang panels in there either, because there is a car in there. My only option is to build some kind of room which kind of acoustically isolates me from the surroundings. Either that or I go and waste thousands of dollars doing all my recording at a studio (my city is very small, prices are high). Even then, I won't be able to mix my songs well due to the terrible acoustics in my room!
Old 19th January 2007, 02:53 PM   #6
TomWaits is offline TomWaits  Canada
TomWaits's Avatar
Sorry to hear you got busted. You "can" mix with a set of closed headphones, then take your recording on the road with you and listen to it on different systems in the car and at your friends home. Once you are comfortable with the set up, you will establish a "reference sound". Make the best of what you have and after you get your references established you will know what to do to compensate. Also, you can have your recordings mastered elsewhere when you feel you are finished with them.
A completely soft surface surounding you is actually not ideal. It should be a balance of hard and soft surfaces.
Many great recordings were made under strange circumstances.
What ever you do, don't give up.
Shawn.
Acoustics - would this work?Hide this!Advertise here!
fm acoustics ben goh Solid State 29 28th May 2012 05:49 PM
Boston Acoustics HD 10 70s music Multi-Way 3 13th June 2007 09:30 AM
Raw Acoustics HT3 audioferret Multi-Way 15 12th March 2006 12:48 AM
Need help in Acoustics! audioPT Multi-Way 13 1st December 2003 10:13 PM
Copyright ©1999-2017 diyAudio
