Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd January 2003, 05:08 PM   #1
chris ma's Avatar
Default Active / Passive how such line to draw
Hello All,
When I look at a power amp schematic (assuming a standard/typical one) how do I tell which part of the circuit is active and which part is passive. Especially the input side of the schematic that normally has a high and low filter network, are these classified as active components? From the ouput onwards to the speaker, is the speaker driver units with its impedance and resistance or capacitance nature also classified as passive. I understand the major difference between a passive black box and active black box, but I am confused with certain parts within the active black box, I think they may be classified as passive parts within a active circuit, please help me clear the muddy in my mind.
Chris
Old 3rd January 2003, 07:03 PM   #2
This sums it very well up.
Old 4th January 2003, 11:30 PM   #3
The one and only
Nelson Pass's Avatar
There are also passive components inside any
tube or semiconductor. You just can't get away
from those passives.
Old 5th January 2003, 02:24 PM   #4
chris ma's Avatar
Default Remove parts at input of power amp schematic
Now If I am to use an external CrossOver device(active or passive) between the pre-amp and power amp, should I go ahead and remove the existing CR and RC the normal low pass and high pass at the input of the power amprefier?
Thanks,
Chris
active vs passive xo howard99 Multi-Way 4 25th July 2007 12:55 PM
Where do you draw the line between tube and sand? leadbelly Tubes / Valves 43 21st April 2005 01:58 AM
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
LM3886 and active xover - how to draw groundplane? AndersZ Chip Amps 16 6th December 2003 09:36 AM
Page generated in 0.07357 seconds (75.33% PHP - 24.67% MySQL) with 10 queries
