Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 11th January 2007, 10:43 AM   #1
Hayden is offline Hayden  Australia
Unhappy Wire gets hot
My wire is getting warm which means I知 loosing power but I知 using fairly large stuff I知 pulling up to 80amps some times at 15v about 1200watts,
I think I have 11awg is that enough? I have 8awg if it will fix the problem, is soundlink a good brand?
Old 11th January 2007, 11:01 AM   #2
Ouroboros's Avatar
I guess this is the 12V feed cable for a high-power amp in a car?
12AWG is 4mm^2 cross-sectional area and has a current rating of 40A.
10AWG is 6mm^2 cross-sectional area and has a current rating of 53A.
If you really are taking 80A then 11AWG isn't enough. 8AWG will be ok, but it's very thick wire!
Old 11th January 2007, 11:01 AM   #3
Geek's Avatar
I used #6 stranded on a CB linear that drew about that
Wire = cool, connectors =
Old 11th January 2007, 11:03 AM   #4
I didn稚 mention its runs a brushless motor for my r/c car and the wire is just under 7inches long
Old 11th January 2007, 11:05 AM   #5
Geek's Avatar
Oh, ok. I think the largest I've seen those is #12
Old 11th January 2007, 11:18 AM   #6
Are all wire the same because I知 using heavy speaker wire or should I be using proper brushless wire that I don稚 have.
There are 3 wires going to the motor the ones with the clear insulation.
Old 11th January 2007, 10:40 PM   #7
I_Forgot's Avatar
Are you sure the wire is heating up due to its resistance or is the resistance of the lugged connection causing heating that is traveling up the wire? The contact resistance is likely to be higher than that of the wire. If you replace the wire with something heavier but keep the lugs your wire may continue to heat up.
I_F
Old 11th January 2007, 11:04 PM   #8
Speakerholic
Cal Weldon's Avatar
Interesting point I_F.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 11th January 2007, 11:09 PM   #9
pinkmouse's Avatar
How does that tiny motor pull 80A without exploding? Have you put a meter on it?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 11th January 2007, 11:10 PM   #10
What charge is in the battery pack?
1700 to 2000mAhr?
How long can you pull 80A in competition before the motor comes to a halt?
regards Andrew T.
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 02:58 PM
Page generated in 0.10039 seconds (79.98% PHP - 20.02% MySQL) with 10 queries
Copyright ゥ1999-2012 diyAudio
