Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Question about potentiometers
Old 10th January 2007, 02:46 AM   #1
SY847 is offline SY847  United States
Default Question about potentiometers
Hey,
I was wondering if it was possible to put a potentiometer in parallel with the signal input instead of in series with the signal line. would the pot still atenuate correctly?
thanks
Old 10th January 2007, 08:29 AM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
Default Re: Question about potentiometers
Originally posted by SY847
Hey,
thanks
Basically, it will depend on the source impedance; if this impedance is sufficiently large, a variation will occur, but on active outputs, this will generally not work properly, as the impedance is very low, and the output circuit will not like being shorted when the volume setting is zero. This arrangement is often used on electric guitars, but even with passive sources there can be problems: in general, the impedance won't simply be resistive, which means the variation will also affect the frequency response.
Also note that potentiometers, are not simply put in series but in a potentiometric (surprise!) arrangement allowing for ~infinite attenuations.
LV
Question about potentiometersHide this!Advertise here!
Potentiometers BlairHatcher Chip Amps 22 9th February 2005 01:24 AM
potentiometers zahlm Parts 1 15th April 2004 06:43 AM
Potentiometers slogan2112 Solid State 2 19th December 2003 07:54 AM
Question about potentiometers. Tomek Chip Amps 13 5th October 2003 09:47 PM
Potentiometers mylar Solid State 3 15th December 2001 06:04 PM
Copyright ©1999-2017 diyAudio
