Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 8th January 2007, 07:37 PM   #1
atsnom is offline atsnom  United Kingdom
Default replacing a 800mA fuse with a 1amp
The fuse in my kenwood amp has blown, its a 800mA fuse, im wondering if its safe to replace it with a 1amp fuse as this is all i have at home and id really like to listen to some music now.
I can get to the shops tommorrow and get a pack of 10 for £1 so if im going to do any damage by replacing it with a 1amp fuse I can wait.
I wasnt sure which sub section of the forum this belongs to so i put it here, hope thast ok.
Old 8th January 2007, 08:26 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
If you knew for sure that nothing is wrong with the amp and the fuse died, well, just because we all die some day, you could do the 1A try-out till tomorrow.
But in most cases, fuses blow for a reason.
It's against all logic to tell you its safe without knowing why the fuse blew. Just like telling someone who can hardly swim to dive in a deep pool. But then, one can drawn in a glass of water.
Also, is it the mains fuse or speaker protection or...?
/Hugo
Old 8th January 2007, 09:01 PM   #3
Its not the mains fues, Ive opened the amp up and taken the transformer out, on the underside the are 4 fuses.
3 are fine, 1 is clearly blown. they are all made of glass and i can see the wire has a break in the middle with a small lump on the end of each break where its melted.
Old 8th January 2007, 09:08 PM   #4
Netlist's Avatar
Go and buy 630mA and 800mA fuses tomorrow.
Replace with 630mA. If it blows, something is wrong.
If you have no experience, take your beloved amp to a good service tech. If it doesn't replace with 800mA and celebrate with a nice glass of wine.
/Hugo
Old 8th January 2007, 11:04 PM   #5
surely if i put a lower mA fuse it it will definetly blow ???
Old 9th January 2007, 12:22 AM   #6
glen65 is offline glen65  United States
The normal operating current will be much less than 800ma.
So you can use the 630ma fuse as a test if it doesn’t blow then
you know the rest of the circuit is ok. If it pops the 630 right off
the bat then you know there’s a problem in the circuit someplace.
Old 9th January 2007, 03:50 AM   #7
thanks i will give it a go in the morning
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
PTC instead of Fuse? gearheadgene Class D 4 8th April 2008 03:42 PM
Why main fuse and not rail fuse? digital desire Solid State 10 3rd December 2006 08:07 PM
amp rating for fuse and fuse holder? riotubes Parts 5 27th August 2006 03:10 AM
convert a 12VDC, 800ma wall wart to 22-24VDC, ~400ma Anthrax Power Supplies 3 9th May 2005 05:44 AM
Page generated in 0.08643 seconds (76.36% PHP - 23.64% MySQL) with 10 queries
