| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I don't honestly know the answer to this question.
I would like to run two sets of 8 ohm speakers (DIY and Bost. Acoustics), off one Adcom GTP-400 preamp, with two different amps (chipamp.com LM3886 and Sonic Impact T-Amp). The preamp only has one set of RCA outputs. Can I split the RCA jack to send the signal to both amps with something like this: http://www.partsexpress.com/pe/showd...number=240-129 The obvious answer to this question is "get a new preamp" but I'm on a budget, as the selection of components would suggest. Thanks |
#2 |
That should work, but...
If you're not using the tape function, you can plug one of the amps into the "Tape Out" jack. |
#3 |
If the tape-out is no option I would use the Y-splitter.. but I would use female to two male rca plugs... you probably won't reach enough distance with the splitter, with this one you can add an interlink and choose the needed distance yourself:
http://www.partsexpress.com/pe/showd...number=240-125
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#4 |
Or get this one if all the connections are too distant (offcourse with two interlinks...):
http://www.partsexpress.com/pe/showd...number=240-127
#5 | |
is not always possible with best result. In this case it depends on how heavy load those 2 are together. A bit heavy load is one amplifier with <=10kOhm input impedance. If BOTH amplifiers are easy load ( maybe >=22 kohm ) than CD-player output may drive 2 amps nicely. For a PreAmp (line amplifier) is not often any problem to drive 2 amplifiers inputs. Even if both are 10 kohm impedance input, it will be a load = 5 kohm. And this is okay for most good preamplifiers. As told, this will a good and simple solution: If you can, check out the input impedance of those two amplifiers. And see what you find. lineup
lineup |
| amps with bypassed preamp question | marko | Car Audio | 3 | 10th January 2009 02:42 PM |
| 4-ohm Speakers on 6-ohm Amp? (newbie question) | diesel_88 | Multi-Way | 23 | 25th October 2007 08:54 AM |
| Would a line stage/preamp be beneficial? NEWBIE question | awhite1159 | Tubes / Valves | 21 | 4th October 2007 11:15 PM |
| newbie question:do i damage the speakers if this is the case? | digitaldiy | Chip Amps | 4 | 17th March 2005 04:16 PM |
| Bracing speakers - Newbie question | Alain | Multi-Way | 5 | 9th July 2004 01:57 PM |
| Page generated in 0.08807 seconds (78.82% PHP - 21.18% MySQL) with 10 queries |
