Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Best way to connect 6ga wire to buss bar?
Old 2nd January 2007, 07:03 AM   #1
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Default Best way to connect 6ga wire to buss bar?
What is the best way to connect some solid copper 6 gauge wire to some copper buss bars? I am looking for the best attachement method. IR lowest resistance. most solid connection etc.
How do that connect wires in big transformers?
Zc
Old 2nd January 2007, 08:40 AM   #2
Geek is offline Geek
Geek's Avatar
Hydro here uses these types of clamps frequently.
Old 2nd January 2007, 09:08 AM   #3
AndrewT is online now AndrewT  Scotland
Big crimp on terminals.
regards Andrew T.
Old 3rd January 2007, 12:26 PM   #4
Zero Cool's Avatar
Guess i am going to have to fabricate some sort of clamping mechanism or find some really big crimp on lugs and the tool to crimp them.
Zc
Old 3rd January 2007, 12:58 PM   #5
chipco3434 is offline chipco3434  United States
Go to the hardware store and buy a "ground lug".
Old 4th January 2007, 12:45 PM   #6
Zero Cool's Avatar
So a ground lug is the best, lowest resistance, way to connect a 6ga wire to a copper buss bar?
Seems so archaic.
Zc
Old 4th January 2007, 01:44 PM   #7
The advantage of mechanical clamping is that if the wire is overloaded and heats up, solder joints won't melt. You could also drop into an automotive store and pick up some battery cable ring terminators. When I have to do work like that, I usually go to my neighborhood West Marine. They'll tag you an extra buck for the terminator but they have a swaging machine for the crimp connection. You can't do 6 Ga. very well in a set of channel lock pliers.
After the mechanical swage, I'll usually throw a torch on the connector and fill with solder... but never just solder for the reason mentioned above.
Old 4th January 2007, 06:28 PM   #8
Ron E is offline Ron E  United States
Ron E's Avatar
Default Re: Best way to connect 6ga wire to buss bar?
Originally posted by Zero Cool
What is the best way to connect some solid copper 6 gauge wire to some copper buss bars? I am looking for the best attachment method. IR lowest resistance. most solid connection etc.
http://www.panduit.com/products/Prod...ins/070358.pdf
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 4th January 2007, 07:58 PM   #9
Nordic is offline Nordic  South Africa
Nordic's Avatar
People underestimate how easily wires desolder themselves.....
wanna clean the solder off some component leads? Just keep em over a lighter flame for a few seconds and tap em against the counter, then wipe them off...
Old 5th January 2007, 12:00 AM   #10
Zero Cool's Avatar
Oh i would have never suggested soldering alone. Yes i have seen weak mechanical connections that have been soldered heat up and melt the solder out!
I just wanst sure if there was some better means that i was un aware of, or a particular brand of crimp that is best for solid wire etc.
I once saw some cables that had been compressed and RF welded to a crimp lug. now that was cool. bet that equipment is expensive!
Zc
Best way to connect 6ga wire to buss bar?Hide this!Advertise here!
Buss grounding for a little amp Calamaro Chip Amps 4 19th September 2008 08:52 PM
twisted pair signal, source selector and ground buss??? cbutterworth Tubes / Valves 2 30th March 2007 08:39 AM
where to connect + wire for Vout? jarthel Power Supplies 2 27th March 2007 05:49 AM
Best way to connect wire to your driver terminals andy2 Multi-Way 1 22nd August 2005 07:48 AM
Brass Buss Bar kilowattski Solid State 6 12th October 2003 08:06 AM
Copyright ©1999-2017 diyAudio
