Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 25th December 2006, 02:24 PM   #1
Audio Junkie
Zero Cool's Avatar
Default Coloring Epoxy?
I am repairing the PCB for a power amp with a kit from Circuit Medic, very cool kit for plated through hole repair. I only have one trace to fix thankfully.
On the Circuitmedic webpage there was a section about epoxy for re-gluing down traces. and there was mention that the Epoxy could be colored to match the PCB solder mask.
This got me thinking. what would a person use to color epoxy with?
I wonder if food coloring would work?
on a side note, i stopped into the local woodworking store to get my Father a gift certificate (he loves wood working) and noticed that they sell large coloring agents for epoxy there. only white and brown however but it looked like jars of very very fine powder.
Zc
Old 25th December 2006, 04:09 PM   #2
TomWaits's Avatar
MG Chemicals have various epoxies. They also have a silver conductive pen to repair traces. I don't know much about adding color to expoxy though.
Shawn.
Old 25th December 2006, 06:34 PM   #3
Check with your automotive paints dealer. They usually carry a good supply of two part bondo type products and resins/cloth for fiberglass repairs. They may not stock colorants, but I'm sure they could order them or give you good advice. I tried looking for epoxy colorants on the web a few years ago and was astonished to find so little info. Maybe that's changed.
Powdered colorants would almost certainly be less risky than liquid since you're not as likely to be adding chemicals that would effect the cure, but liquids mix much better. For electronics you also have to worry about losing dielectric properties - in which case, you probably ought to email someone like 3M to be really certain.
Here's a pretty good PDF to start you out...
http://www.westsystem.com/ewmag/21/p...1_pigments.pdf
good luck.
Old 25th December 2006, 07:39 PM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
doubt if green food colour would make it red if you catch my drift...
Old 25th December 2006, 09:25 PM   #5
spzzzzkt's Avatar
Take a look at this article on coloring epoxy:
http://www.westsystem.com/ewmag/21/pigments.html
The west system epoxy is pretty nice stuff to work with - I've used it for building composite construction radio control gliders. It can benefit from warming when being used to about 40degC/100degF get it to flow nicely.
cheers
Paul
Epoxy covered crossover?? Ryder Multi-Way 10 24th August 2010 12:06 AM
Coloring Cones dzzmiller Multi-Way 8 17th March 2009 06:27 AM
Epoxy or PVA Mos Fetish Multi-Way 2 4th February 2006 10:57 PM
Debond epoxy Pbassred Solid State 6 7th April 2004 04:38 AM
Tube Preamp Coloring Box? skipbeach Tubes / Valves 2 14th April 2003 04:04 PM
Page generated in 0.08437 seconds (74.65% PHP - 25.35% MySQL) with 10 queries
