| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
does not need to be any danger
our fingers can not take the heat that semiconductors can what this indicates, is that keyboard draws High Current and so the power in diodes is quite a bit. 19-16.5 ~ 2.5 Volt say 3 Ampere Power dissipated in diodes= 2.5V x 3A = 7.5 Watt. ----------- What you can do: 1. place these 4 diodes not to close to eachother 2. place them in free air = not close to any PCB surface this will allow air to flow and COOL from ALL sides of each diode 3. usually we can let the pin of such HOT devices be a bit longer so that the body of device is LIFTED like 5 mm ABOVE PCB Other components like small resistors etc. have there body close to board to reduce the length of connection pin. This is generally good. But for HOT diodes or POWER Resistors (without Aluminum heatsinks) can be good to keep them a bit up in air. ************************************************* If you still worry about heat in your diodes, there are Rectifier Diodes in TO220 package. Which allows you to screw a little Aluminum metal piece onto diode. This image shows a TO220 package, with one diode. Has got 2 pins, instead like a TO220 transistor = 3 pins ****** sidenote: TR-ansistor TR-iode ---> the TR comes from TRIO = 3 TRiode - 3 pin diode (a sort of Tube / Valve, which was before all Transistors) Lineup Lineup Audio knowledge Bureau http://lineup.awardspace.com/
lineup |
#12 |
What is the number of this 2-pin TO220 rectifier diode?
SUNNY. |
#13 | |
Check the website of your Electronics Dealer. Browse: Components - Semiconductors - Diodes .... And look for single diode in TO220 package(capsule) that is rated something like 5-10 Ampere. Maybe someone member from your neighbourhood, country would be so kind give us a Link to supplier or Part Number of one such suitable Rectifier Diode. All the big semiconductor manufacturers make such high Current Diodes: SGS Thomson, Philips and them from Japan, Korea, China, too. There are plenty of variants for different voltages and currents. lineup
lineup |
#14 |
still i cannot find this 10A rectifier diode.Please suggest me suitable low cost 10Amperes diode.
Thanks, SUNNY. |
#15 | |
in INDIA. I can go there have a look for you. Members from India, where are you, this christmas? lineup - knows there are several other active and good members from India
lineup |
#16 |
IRF has got a line of such diodes in TO220 package
The thing is maybe to find a supplier, preferably in India or not too far from you. But if you can buy from other countries, like from Online electronic web shops, then is no problem. Like Singapore, Hong Kong, Japan etc. If you live near New Dehli you can go buy them in a shop, for sure. Here are 2 suitable diodes from International Rectifiers www.irf.com Two TO220 power diodes from - irf.com - International Rectifier They are called: 10ETS08 ( 10A, 800 Volt ), 10ETS12 (10A, 1200 Volt) You would only need max 100 Volt, so both of them will do, more than enough! 10ETS08 Datasheet PDF - with details These diodes will cost you more money, than if you go for normal Axial 2 pin Power diodes. I think those you have now ( 6A ) will do well - if you put them in free air for some cooling ( see my prev. post ) but of course you can upgrade to 10A, if you like. lineup
lineup |
#17 |
Can i use 10A1 diode?i think It is a Axial 2 pin Power diode and is this diode costs less than 10ETS08 or 10ETS12?
SUNNY. |
#18 | |
this would be perfect - and better price, if you can find a shop. Generally it is good to have some margin: Use 3A diodes for 1 ampere currents Use 6A diodes for 2 ampere Use 10A diodes for 3-4 ampere The same goes for Transistors and Resistors. No components will work at best, when they have to do HEAVY WORK. Same goes for people. A little child can not carry so much weight, in a good way, as a big mother can. See my attached Picture, with Image and Details of 10A1 The manufacturer is called Rectron datasheet: http://www.rectron.com/data_sheets/10a05-10a10.pdf 10A1 It is an axial 2-pin power silicon rectifier diode FEATURES * Low cost * Low leakage * Low forward voltage drop * High current capability * High surge current capability MECHANICAL DATA * Case: Molded plastic * Epoxy: Device has UL flammability classification 94V-O * Lead: MIL-STD-202E method 208C guaranteed * Mounting position: Any * Weight: 2.08 grams lineup
lineup |
#19 |
Thanks a lot for helping me.Now my problem has completely solved.
SUNNY. |
#20 | |
FIG. 2 - TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS the 10A1 power diode has got a voltage drop ( VF = forward voltage ) of something like 0.8V at 3A so we can think 3 diodes would have a drop of ~2.4V 4 diodes would have a drop of ~3.2V .... something like that you are welcome back if there is anything else you want to discuss or ask in electronics as you know, we are many here that could possibly try to give advice Regards to sunny, India from lineup, Europe |
| Need help with my ST70, decrease in one channel | JayH3 | Tubes / Valves | 1 | 17th December 2008 03:26 AM |
| How to decrease this voltage? | sunny | Power Supplies | 8 | 31st December 2006 10:33 PM |
| Rail Voltage to Capacitor Voltage | Mermprin | Parts | 6 | 20th September 2004 03:56 PM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
| Rail voltage compared to transformer voltage | SteveG | Solid State | 4 | 22nd July 2002 11:50 PM |
| Page generated in 0.11585 seconds (81.18% PHP - 18.82% MySQL) with 11 queries |
