There are tons of different DeoxIT products, which ones are the most useful?
Possible uses :
-Cleaning old potentiometers,
-Cleaning cigarette smoke in old equipment,
-Cleaning front plates,
-Removing oxydation,
-Protection against oxydation.
Should DeoxIT alone work?
What about Progold, Progold GxL, etc. ? it seems you should put some after DeoxIT, so what's the big difference with DeoxIT shield, etc.
Possible uses :
Dragon
I use CAIG DEOX-IT 100 for cleaning pots.switches and any electrical contact surface for removing and inhibiting corrosion/oxidation. Windex works wonders on front plates and plastics. Smoke,dust and pet hair-compressed air and electrosol electronic parts cleaner. Use deox-it sparingly it is rather costly and a little goes along ways😉
Dave
Dave
A little does go a long way...
If you get the stuff in the spraycan,be careful!
The first time I used it I ended up having to wipe down half the chassis! Even with the variable-spray nozzle thing turned down,it still squirts out alot,even with a quick push.
Dragon
It definitely has everything but those little areosol spray cans don't last very long . If you use it very sparingly maybe a dozen potentiometers..Now the wipes are great for RCA jacks and plugs.
Dave
Dave
I see... I have a few amps to restore (About 35 pots/switches/selectors to restore/clean, some PCBs to clean)
- General Interest
- Everything Else
- Which DeoxIT do you use
