Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th December 2006, 02:46 PM   #1
neutron7's Avatar
Default carbon fiber used as EM shield?
Carbon fiber conducts electricity rather well I was wondering how it would work as electromagnetic shield, or is it something else about metal that does that?
I was thinking of bulding a carbon fiber amplifier housing. since i have some of the cloth spare from another project.
Old 16th December 2006, 05:45 PM   #2
I_Forgot's Avatar
Carbon fiber will work as a electrostatic shield but just like aluminum, it won't help with low frequency magnetic fields.
I_F
Old 17th December 2006, 09:53 PM   #3
neutron7's Avatar
how about embedding some of this http://www.twpinc.com/twp/jsp/product.jsp?type=3
copper RFI mesh in the carbon between the layers.
Old 17th December 2006, 10:31 PM   #4
I_Forgot's Avatar
I don't think you need to. The copper mesh blocks RFI because it is a conductor that will ultimately be tied to the ground of your circuit. The carbon fiber will do the same thing, just as an aluminum enclosure would do the same thing. The copper mesh is normally used where you need to have shielding and air flow.
Copper is a bit better conductor than carbon fiber, so it may be slightly more effective, but how effective do you need it to be? It is one thing if you're trying for agency approval to mass produce a product and another if you're building a single device for your own use.
None of these shields (aluminum, CF, or copper mesh) will protect your circuit from low frequency fields such as those found in the vicinity of power transformers.
I_F
Old 18th December 2006, 02:23 AM   #5
neutron7's Avatar
great then you saved me $75
Old 18th December 2006, 02:52 AM   #6
I_Forgot's Avatar
I have been considering using it for the stators of an electrostatic speaker. It should make for a stiff, light driver.
I've been trying to figure out how to pull every other cord out of plain weave cloth so it will be perforated. I need to attach the whole cloth to a frame, then cut every other cord and pull it out. It would probably be cheaper to buy the cord and just wind it over a frame with a bunch of nails or slots spaced evenly around the perimeter.
Aircraft Spruce has 1 lb rolls of 6k tow for about $50. I figure a pound of the stuff would be good for a decent sized pair of speakers.
I'd fill the frame with the stuff, then slather on the epoxy, then vacuum bag the whole thing. After the epoxy has fully hardened cut it away from the frame. The frame will have to be a throw-away part so figuring out how to make it quickly, easily, and cheaply would be the main challenge.
I_F
Old 19th December 2007, 04:59 PM   #7
Nordic is offline Nordic  South Africa
Nordic's Avatar
Well i'd say you can use those powedery molds similar to old fashioned sand... you make an impression in it, say, useing a wooden block, then fill it with whatever you are casting with... obviosly you need to put your wires and stuff in the prepared hole before filling...
carbon fiber cones? thoriated Multi-Way 21 28th January 2009 08:02 PM
DIY carbon fiber brush marekst Analogue Source 2 19th February 2008 04:17 PM
carbon fiber earing Instruments and Amps 8 13th March 2007 05:04 AM
How do I use carbon fiber + MDF wood + glass fiber to make speaker? sonyacer Multi-Way 16 10th May 2004 03:57 PM
Cutting Carbon Fiber user510 Analogue Source 6 25th December 2003 04:40 AM
Page generated in 0.08040 seconds (77.32% PHP - 22.68% MySQL) with 10 queries
