Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
How can I check if its balanced output
Old 8th December 2006, 04:41 PM   #1
Pbassred is offline Pbassred  United Kingdom
Pbassred's Avatar
Send a message via MSN to Pbassred
Default How can I check if its balanced output
I have a music effect which is designed with a TRS jack on the output. However the manual doesn't say that its balanced. I don't own a scope.
How can I check if it is a balanced signal?
Jeeees! I only asked
https://www.facebook.com/dave.potter.5815
Old 10th December 2006, 11:52 AM   #2
Burnedfingers is offline Burnedfingers  United States
Hook up to sleeve and tip and you should have signal.
Hook up to sleeve and ring and you should have signal.
If there is only signal at tip and sleeve then its not balanced output.
Old 10th December 2006, 12:03 PM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I would guess it's most likely a send/return loop if it's an effects box.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 10th December 2006, 12:14 PM   #4
Pbassred's Avatar
Thanks pink, but its not that kind of effect. Its definatly output only.
How can I tell that the tip and ring are oposite - i.e. not just the same signal down both? would I get an output from connecting the tip and ring?
Old 10th December 2006, 12:15 PM   #5
pinkmouse's Avatar
Possibly stereo out? What's the effect?
Old 10th December 2006, 12:41 PM   #6
measure Vac tip to ring,
then sleeve to ring
and finally sleeve to tip.
Tell us what you get.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th December 2006, 01:45 PM   #7
Pbassred's Avatar
http://www.line6.com/basspodxtlive/
No. It really isn't balanced. Tried the outputs Ring to screen is dead.
Old 10th December 2006, 02:16 PM   #8
It seems they have fitted a TRS plug, just to confuse.
Look inside the unit.
Is the ring disconnected?
If yes, then what about swapping it for a TS plug.
regards Andrew T.
Old 10th December 2006, 07:26 PM   #9
Pbassred's Avatar
There is a DI (clean) out and a "Model" (effected) out
http://i76.photobucket.com/albums/j2...tputjacks2.jpg
....................and they're marked Left and Right!
I will take the PCB out over Xmas to see how its connected, but its a bit of a chore. Its no biggie. I have a DI box.
Old 11th December 2006, 10:54 PM   #10
chrispenycate is offline chrispenycate  United Kingdom
chrispenycate's Avatar
Some effects used the fact that a R-T jack was inserted into a TRS socket turned the device on; unplugging it removed the battery connection. Nice ground currents, not to mention the confusion if you feed it into a balanced input.
How can I check if its balanced outputHide this!Advertise here!
Balanced gainclone sanity check xiphmont Chip Amps 56 6th June 2007 06:12 PM
How to check output transformers ? 00940 Tubes / Valves 2 7th April 2004 10:51 PM
ono balanced output pamaz Pass Labs 6 3rd March 2004 11:20 PM
Converintg analog stage to balanced on dual diff dacs? check pic. kasra Digital Source 14 31st August 2002 10:11 PM
Copyright ©1999-2017 diyAudio
