| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
I'd like to interject something here....... Whats the point of audio compression formats for anything other than portable devices with limited storage?
The reason these formats ever evolved in the first place was to save valuable storage space. I think we have hit a point where cost vs. size no longer necessitates this need. You can buy a 400gb hard drives on ebay for $100. Thats enough room for over 500 full length CD's without any compression.
#12 |
Anonymous,
Audio compression is for someone like me, who only has 18GB total in space and doesn't want to have to devote his whole computer to music! And if you can save space, why not? It may be different with you, but I don't have $100 for me or my family to spare. Does anyone know of any good general open source project forums? I could probably get some good answers there. - keantoken |
#13 | |
I think a lot of people out there concerned with the quality of their stored music CAN afford larger storage devices. I was simply bringing up the fact that for those people technology has passed a size vs. cost barrier that no longer requires one to search for the perfect lossless format. |
#14 |
Thank you for being apologetic, however I was by no means trying to sound like I did. I am ridden with a horrible social skills that show even in my writing, so no need for apology.
I do favor the quality of my music, as well as my photos - That is why I never use JPEG! Instead, there is something way better - PNG! Lossless? You bet! Look at this link: this picture is a 4096x4096 PNG that includes all of the colors in the 24 bit spectrum. Only 58 Kb? This isn't a bluff! http://www.3-t.com/pub/png/img_png/1...n-pschmidt.png Unfortunately, not many image editing programs take full advantage over PNG's filtering compression capabilities.... Here is the official PNG home site: http://www.libpng.org/pub/png/ - keantoken |
#15 |
Okay, to maintain the topic (hehe... I forgot my own dictum!), I have been working on my equations all day in school. These are my ideas for my codec:
1: Have adjustable average samplerate. Quality vs. compression - maybe not lossless... 2: The equations involved could be manipulated to form a lowpass filter to filter out high harmonics, using the nonlinearity property of the sinusoidal Method of Processing, as described in the PDF Not an especially long list, but I think more will be added later. Here are my first ideas for the equations: Variables: A=value of current sample | S=input samplerate B=value of previous sample | N=nominal output samplerate Equation: (A) (C) sin (((abs (A)/abs (B))/S)*1.570796327) Definitions of the equation numbers: 1.570796327=pi/2 Info: abs (A)/abs (B) (A) produces the slew rate, and /S (B) turns it into a number from 0-1, then *1.570796327 (C) translates it into a number between 0-1.570796327 which is the desired range since sin (1.570796327)=1. The peak of the sine wave is at the point of maximum slew rate because here, the output of the codec needs to level out - which filters higher frequencies to increase compression. Problems: 1: The abs (A)/ abs (B) thing was used to keep numbers positive so that the output of the whole equation is positive, making it easier to implement in a program. What happens if A is negative while B is positive? This means that the input crossed zero between the times when the samples were taken. 2: It is true that the output of this equation is zero when a 20,001Hz sine wave is give to the input, but if it goes over that, then the output will begin to fall again because of the nature of a sine wave. This would cause weird problems when ultrasonic (>20KHz) waves were give to the input. To fix this, there would have to be a limit that causes the result of the equation in parentheses to never go over 1.570796327. This would have to be implemented in the code. If you need something clarified, which you probably will, because I am not used to explaining complex things, just ask and I will do my best to answer your question in an understandable manner. I do not want this discussion to stop! - keantoken |
#16 |
keantoken
You are way above me in maths and in advanced ideas. Are you a professor or so? If I recall you are quite young. I guess you are #1 in mathematical in your classroom. Maybe even best in your school .... ? This does not necessary mean you are able to accomplish a good diy audio system. At least not better than our experienced practical builders can. But sure, it can help a bit. You will learn more quickly, when having a bright intellect. Regards lineup |
#17 |
Thanks, lineup!
I may be considered intelligent, but as you said, I still have quite a ways to go. I am not necessarily the best in my classroom or school, but my edge is my knowledge about math. I got interested in trigonometry when I first saw what sin (x) would do on a graphing calculator, and then I wondered what this motion was used for. Then my math teacher last year let me look through her trig book and I discovered the relationship between circles and sine. I also gained a lot of it just sitting somewhere and programming my graph calc, trying to make programs that would figure out resonant frequency, and rotate shapes and tons of other stuff. This is also where I got interested in programming. If I had a mathematical question to ask, I would make a program in my calc to figure it out! I am not the fastest in my class to figure things out, but I can draw out equations and identify patterns better than anyone in my school that I know. I have to try not to get a big head, though, since this can cause you to stop learning because you think you know it all when there is much more to know. About the equation, I believe for problem #2 I can use something like this: sin (abs(abs (A)/abs (B)) Also: If anyone has heard of Winamp, which I am sure lots have, I believe that I could use it as a testing host. I could program my input and output plugins with the Winamp API. All I need, from what I read, is some knowledge of the C programming language. I know a little, but I am going to try and learn as much as possible over this weekend do that I can get started right away! -keantoken |
#18 |
sinus and cosinus
can be very useful in audio calculations because the most commonly used audio waves for testing amplifiers and components and amplifiers and circuits are sinus and square waves sinus is based on the formula for a circle Circle perimeter = 2 x PI x Circle radius we so often see use of the value PI (3.14) and 2 x PI (6.28) in audio The other value often used is square root of 2 (= 1.414) Often these two values are combined in several ways: 1.414 and 3.14 (and the associated values of 0.707 and 6.28) For example the -3dB frequency of a simple RC filter f = 1/ ( 2 x PI x R x C ) I haven't bothered to memorize more than maybe 3-5 important formulas for audio. U = R x I (ohm's law) and the above RC formula will cover most any math we need to setup a good amplifier. Scientific pocket Calculators and Simulators can do the rest, for anyone, without the need for any knowledge in maths. -------------------------------------------------------- About learning. It is not those quickest and most brightest that always become the most skilled, or even professors, in the end. For best learning you need motivation and desire to learn something. When you are really interested in something, you will learn. Talent is good, but motivation and drive is better! lineup
lineup |
| FS Speakers, audio components, development tools, lab equipment... | Kabigon | Swap Meet | 7 | 21st July 2009 12:49 AM |
| Please advise a 20- or 24-bit Audio Codec with Differential Inputs/Outputs. | skpb | Digital Source | 2 | 9th January 2006 03:27 PM |
| USB audio codec with SPDIF or I2S out | bocka | Digital Source | 9 | 15th June 2005 08:31 AM |
| Altera CPLD based DIY Audio Development kit | solomon2773 | Swap Meet | 0 | 11th January 2005 03:40 AM |
